![]() | Home > Maintenance & Modifications > crystal headlamp, does brand matter ? |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
puts you into the comfortable position to get loads of cheap used replacements, in case you damage yours. |
pumaxs Member Since: 18 Jul 2012 Location: Bath Posts: 180 ![]() ![]() ![]() |
Have Crystals fitted (bought from Paddock) + uprated bulbs, and very pleased with the set-up.
However, I will be driving to Bellagio, in Italy, later in the year. Any ideas on how to correctly 'blank' them for driving on the wrong side? '57 Defender 110 XS Station Wagon 2.4tdci |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
You can have mine out of my defender in August for a tenner if you like. I will be in Swindon then so not far away. They are as new ![]() |
Are they with or without 'pilot light'? (What is a pilot light, by the way?) A tenners not too much for a viable plan B, so I'm up for it. When are you back in Swindon? - I go away the first week of September. '57 Defender 110 XS Station Wagon 2.4tdci |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20946 ![]() ![]() |
A sort of sidelight that is separate to the H4 bulb. Usually around 5w IIRC. And work in the same way as actual side lights but actually mounted in the headlight bowl. (You don't want them at all! Look awful and won't suit either.) ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Good as DRL's. much better than Angel Eye lights
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
But not as pretty
Depends if you want to take part in the Saturday night sea front promenade in Southend.
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
well I just purchased, wipac crystal bowl, SS bezels with SS clamps and black screws, and osram nightbreaker plus 90%.
Sorry for late the reply! They have a pilot light which you can either use or not bother and wire it to come on as you see fit. Its a small push fit 5w bulb. Back yo UK first week of August and will take 10 mins to swop them over. |
