|  | Home > Puma (Tdci) > Propshaft greasing etc ..... |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | The prop will need to be in the correct position to get onto the nipples.
 And if you have zero backlash I assume you had the hand brake on   If you do have loads of slack in the front will probably be diff, this can be adjusted, although it can also be the combined play in many items adding up. How much play ( degrees ) do you have? Nuts and bolts can be reused, I have many times, but good practice is to replace the nylocks a each time, but I've never lost one yet. Andy Last edited by landy andy on 8th Jul 2013 10:04pm. Edited 1 time in total | ||
|  8th Jul 2013 10:01pm |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391      |
 Nope... Up on stands with brake off!!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB | ||
|  8th Jul 2013 10:02pm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059    | Wow, you must have a good one     Andy | ||
|  8th Jul 2013 10:05pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052      | You should really disconnect at least one end of the shaft when greasing since it is the only way to articulate the joints fully. | ||
|  8th Jul 2013 11:10pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | I grind one side of the grease gun to within an inch of its life but often the grease nipples come pointing at the yoke and not out to the gap. So much for PDI and servicing care. I got a brand new front prop on the front due to the supplied shaft coming with no nipples from the factory. The new shaft was fitted ungreased and the nipples were impossible to get the gun on as they were pointing toward the yoke... Disgusting!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  9th Jul 2013 4:17am |
| jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149      |
 Remove the existing grease nipples and replace with 'long necked' grease nipples (Obtained from motor factors).
 Alternatively, arm yourself with midget spanner (BA) and turn the grease nipple to accept the grease gun valve. No need to faff around with propshaft. El pepe Flamenco.  JLS 'El Pepe Flamenco' | ||
|  9th Jul 2013 12:50pm |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363    | Ihave done all that Sherlock but a standard PCL or Teclamit grease gun won't fit the front UJ. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. | ||
|  9th Jul 2013 1:34pm |
 Buy yourself a new grease gun with a small valve (a decent one)!!
 (Sherlock!) JLS 'El Pepe Flamenco' | ||
|  9th Jul 2013 6:03pm |
| Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514      | Quick question, could someone give me a link of where I can obtain the grease that I need to use please, many thanks,
  Cogito ergo sum | ||
|  10th Jul 2013 6:49am |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18052      | I use Castrol LMX.
 Edit. After posting I find that LMX is now discontinued in the UK but it isn't entirely clear what Castrol consider its replacement to be. I will email Castrol to find out. | ||
|  10th Jul 2013 8:09am |
 Top man, cheers blackwolf  Cogito ergo sum | ||
|  10th Jul 2013 10:44am |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813    | http://www.championlubes.com/EN_EU/product...e=91046677
 or similar. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai | ||
|  10th Jul 2013 4:36pm |
| bunnyman Member Since: 29 May 2013 Location: herts Posts: 126      | Having the same problem with my grease gun fitted the td5 keeps sliping off of the tdci must be different size ? | ||
|  11th Jul 2013 2:53pm |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109      | http://www.stephenslube.co.uk/grease_guns.asp
 These have been mentioned in the past but I can't remember which nipple it was  | ||
|  12th Jul 2013 9:51pm |
| Posting Rules
