![]() | Home > Technical > None start |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 ![]() ![]() ![]() |
Yes. Or at the least a voltage regulator possibly. Rhubarb and custard let fly with their secret weapon.
Scott90 Member Since: 10 Jul 2013 Location: Crieff, Scotland Posts: 187 ![]() ![]() |
I put a new alternator on it.......still not charging?????? Pos faulty altarnator?
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Check the nut on the starter motor (where the main battery cable connects on to) isn't loose... a common fault, giving "flat battery" symptoms.
NOTE: i'd disconnect the battery first before you try to tighten up said 13mm nut, lest you touch any part of the engine/chassis/earth point with your spanner, as it'll lets the sparks out. |
