Home > Puma (Tdci) > Dash warnings.
RED-DOT
Dash warnings.
My red brake, amber ABS and amber TC warning are now on all the time. Is it an ABS sensor and any way of finding or testing without booking it in to the dealers?
Thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #250465 10th Jul 2013 12:22pm
It could be a sensor, but it could also be chaffed wiring, which a few Puma owners have reported, or even a wheel bearing.
Chaffed wiring is the only one that would be visible, but even that might need a diag. check to determine which wheel to look at. Darren
Post #250471 10th Jul 2013 12:43pm
camelman
Have a look on this thread, http://www.defender2.net/forum/topic21616.html
The unit reads / clears fault codes as well as streaming live engine data to your phone / tablet Smile
All for under £15 Very Happy
Post #250492 10th Jul 2013 2:30pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Red Dot,
I have the same issue and believe it to be a sensor as it started gradually coming on after 20 minutes of driving, and now it comes on every time.
If you want a short term solution, get yourself going at a reasonable pace, put the clutch in and let it freewheel while you switch the engine off and start it up again and let the clutch out. Razz Lights out Razz
Also some people have had earthing trouble with one earth on the bulkhead behind the water expansion tank and also on the inside of the chassis rail next to the battery box. Worth a check there and also whether the terminals are tight.
Cheers,
William William
Post #250493 10th Jul 2013 2:32pm
RED-DOT
Just tried a hard reset but still on.... will give all suggestions a try. I mashed a cable in a rut and a quick fix was done four years ago so i will check the repair hasnt come undone. It is known as the 3 Amigos i believe. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #250504 10th Jul 2013 2:58pm
theorangebandit
I had this problem the lights were intermittent , it turned out to be a chaffed wire, don't know which one I took advantage of my 1 year land rover warranty
Post #250520 10th Jul 2013 4:09pm
vogue se
Belgium 2011 Defender 90 Puma 2.4 Exclusive HT Nara Bronze
With my 2008 Defender, the dealer had to replace the wiring of the back axle. That is a common failure.
Post #250544 10th Jul 2013 6:27pm
K9F
RD.....
Hope these help..... Thumbs Up
Page 3 of the first link. Resistance figures for each sensor should be about 1kohm
http://www.defender2.net/forum/topic2394.html?highlight=abs
http://defender2.net/forum/topic20879.html?highlight=gap If you go through life with your head in the sand....all people will see is an ar5e!!
Post #250650 11th Jul 2013 3:04am
