![]() | Home > Puma (Tdci) > 2.2 Turbo/Intercooler pipe recall. *** WARNING *** |
Very true but you won't be stranded (not for that anyway ![]() If you're that worried carry a spare OEM set perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 617 ![]() ![]() ![]() |
I agree - frustrating. I think a spare is a good idea. Next time at the dealer i'll get them to hand one over.
I'm sure i'll be there soon for EGR valves or broken electric windows ![]() |
clwlaptop Member Since: 21 May 2013 Location: Neath Posts: 65 ![]() ![]() ![]() |
I'm traveling to france for the family holiday in a few weeks. One of the kids is disabled so breaking down is the last thing I need to do - so why did i buy a defender??? Anyway - Just had a look under the bonnet seems to be plenty of room between pulleys and hoses - am I looking in the right place? I guess things must move/expand??
Will keep an eye out for damage. ![]() Click image to enlarge ![]() Click image to enlarge |
zahy Member Since: 02 Jun 2013 Location: East Sussex Posts: 150 ![]() ![]() ![]() |
i strongly recommend that you keep a close look at the turbo hose clip, had this problem last weekend and my delaer had to fit two clips to keep ot tight, according to land rover they are working on a fix for this problem, the last thing you want is to break during your holiday- enjoy |
This hose coming off of the 2.2 Puma is such an old ill that it is almost not credible to believe that LR have not found a fix for what must be a really minor engineering issue. Below is a link to a thread on this topic which is now more than a year old, and problem still ain't solved ![]() ![]() http://www.defender2.net/forum/topic12314....p;start=45 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
funny enough i did pass this information in my complaint to LR, who called back to apologise ( in other words telling me to f off) and when i asked for her comments that the same problem seems to be an old issue she replied that LR is always cautious before issuing any fix and that they currently are still testing the "modified part" i personally cant see this testing ending any time soon!! maybe the new fix is the DC100 |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
I thought Land Rover got their customers to test their vehicles for them
I'll keep a close look out then. Thanks!!
Worth checking the other side too where the alternator is!
![]() Treat every day as if it is your last....one day you will be right!! |
GOTCHA. TA!!
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
holgerb Member Since: 08 May 2013 Location: Baden-Württemberg Posts: 9 ![]() ![]() ![]() |
New friction point: Intercooler-duct vs. mounting plate for airfilter-unit!! i'm looking for suitable material to fix this problem! Regards, Holger |
So my MY2013 110 went in to have the new bracket mod fitted to prevent me needing a 4th intercooler/turbo pipe in a year.
The bracket is in two pieces. One section (comprised of two pieces) bolted to the alternator and holds the pipe securely. Here is it with the first part bolted to the alternator - you can clearly see where the steering column has been rubbing through the 4th pipe as it shiny and clean: ![]() Click image to enlarge And here with the second part enclosing the pipe : ![]() Click image to enlarge There is also a second bracket that is bolted just behind the front grille and the pipe rests in this rather than being bolted in: ![]() Click image to enlarge **** HOWEVER - PLEASE CHECK THIS ****** To fit the bracket the dealer has to remove the air box : ![]() Click image to enlarge When they do this the bracket mounted to the wheel arch liner can be easily broken - as they have done to mine : ![]() Click image to enlarge I asked to be in the workshop when they fitted the bracket and the force they used to remove the air box was ridiculous. When they broke the bracket I was told not to worry as "that always happens" and that "the other mounting point is more that enough to hold the air box, you don't really need two." If i hadn't been in the workshop I'm sure they wouldn't have told me about the bracket. So in short, It goes in tomorrow morning to have a replacement air box bracket fitted, that was broken when they fitted the updated bracket that they had to do to stop the 110 eating its 4th pipe in a year. Quality product, quality dealers. **** PLEASE - make sure you check your air box bracket for damage AFTER the updated turbo bracket has been fitted ***** |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Which dealership was it mate?
