![]() | Home > Maintenance & Modifications > Windscreen rubber replacement |
It is do-able for a competent DIY-er (although I haven't done it myself!). Basic method is to feed a piece of cord/string inside the rubber, fit the screen with rubber attached into the frame, then pull away the string so that it pulls the rubber outwards, so as to fit nicely around the frame! Hope that make some sort of sense? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Putting the issue of heated windscreen to one side,it's an easy job fitting a windscreen.
1.Fit the new seal to the screen usin a bit of washin up liquid for lube if needed. 2.Run plenty more soap around the seal where it meets the window frame and insert a strong cord into the grove,again lube the cord with PLENTY of soap, I used to use one of the cores from 3 core domestic. 4.Place screen against frame with the cord/wire inside the vehicle,you or someone start pulling the chord slowly from the inside at the same time a second person start pushing/hitting seal (from outside the vehicle) to help locate the seal to frame,it will be immediately obvious from inside the vehicle as to whether the seal is fitted,or not. Never fitted a heated screen don't know how delicate the eleky bits are. Tips; Use plenty of soap. Peel back the seal inside the vehicle and look how the rubber seal is fitted to the frame before removal. Use plenty of soap. Don't drop the glass. |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Christian I got local windscreen company to fit mine as I was sure I would break the screen putting it back in. ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
You're more likely to break the glass getting it out, and if there are any chips or cracks it is more likely than not it'll break. My recommendation is to get a good independent windscreen fitter to do it.
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 ![]() ![]() ![]() |
The screen itself is I good condition however given the feedback here I'm going to bottle it and get a professional to do it. The though of paying for a new heated windscreen is putting me off
![]() Thanks for the advice from all though ![]() |
Had a heated fitted to the project 90 on Monday with a new rubber according to the fitter new rubbers are
![]() However it's safe practice to always use a new rubber ![]() |
Sound advice indeed ![]() |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
me and the wife fitted one on sunday. we had a couple of false starts but it went ok in the end. i must say, i used to fit volvo truck windscreens and this seemed a lot harder. but i was re using the old rubber back then
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1286 ![]() ![]() |
I paid Autoglass to do mine.
As stated, its the new rubber thats the problem....the guy fitting mine had a real struggle.. Also i had to sign a disclaimer to say i accepted responsibilty if the windscreen broke!!!! The older the screen the more "brittle" they become. Clemmo |
Bearders Member Since: 10 Jan 2013 Location: West Midlands Posts: 9 ![]() ![]() ![]() |
I had the same decision a couple of weeks ago - my rubber seal was also very badly cracked.
Bought a new genuine heated screen and rubber (WLR on ebay had a load of screens at £119) but got a local windscreen firm to fit. Glad I did as they had a bit of a game, I ended up not watching - sure they were going to break the screen. Fitting cost me £35 and they disposed of the old screen, took less then an hour in all. As an aside, the old one had a large chip at even with them cutting all way round it cracked as they tried to remove it. |
my old screen cracked........when i leaned back and kicked it out with both feet lol
Thats wot we used to do,2 of us pushin em out wi our feet,no cracks tho ![]() |
There's no way I'm doing this now .....
Going to get one of the local companies to do it for me...... Kicking the screen out seems like fun though ![]() ![]() |
Just picked the car up from Strathearn Engineering who fitted the new windscreen rubber seal for me. Three man job to get the new seal in so glad I never tried it myself.
I would be paying for a new windscreen just about now. Top job as ever guys so thanks ![]() |
