![]() | Home > Technical > Oil specs for 2.2 and 2.2 non DPF |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Spec sheet for oil for Puma 2.2 with DPF
http://www.championlubes.com/TDS/tds_65605...018_lr.pdf Spec sheet for oil for Puma 2.2 without DPF http://www.championlubes.com/TDS/tds_65609...158_lr.pdf Spec sheet for oil for Puma 2.4 http://www.championlubes.com/TDS/tds_65609...158_lr.pdf Seems that if you live in a country where your new 2.2 Puma does not have a DPF fitted you can use the oil used for the 2.4 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2683 ![]() ![]() ![]() |
Interesting, was not aware there is now a 913-D spec --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
News to me too. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
