![]() | Home > Puma (Tdci) > cables why?????? |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Probably as one would snap knowing LR quality??
Mine has twice! 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
There's a few behind the heater controls too.
![]() ![]() ![]() ![]() Click image to enlarge ^^ Proof! ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
I've just recently had to remove the bonnet brace for an intercooler fit. It only had one cable at the business end! ![]() Treat every day as if it is your last....one day you will be right!! |
bunnyman Member Since: 29 May 2013 Location: herts Posts: 125 ![]() ![]() ![]() |
sometimes i think i might have been easier with the td5, 1 cable, somebody must know the technical reason for two ??
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 ![]() ![]() |
Bonnet's expected to be open twice as often so you need twice the cables to take the wear?
![]() XS 110 Utility maybe one day..... (did they fix the quality yet?) |
I presume you mean it has 1 cable with a split in the middle - making 2 parts?
Yes one cable split in two ,isn't it easier and cheaper just to have one cable?
Perhaps they came across a stockpile of NOS Marina or Alegro bonnet cables so decided to use them but as they were a bit short had to fit an extension cable
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
It's probably to help with some aspect of the build process. Either that or to make it easier to replace a broken end without having to re-thread the entire cable. Darren
