Home > Maintenance & Modifications > Fuel tank guard for Puma 90
Page 2 of 2 <12
JSG
Lambley wrote:
Cheers SteveG, yes it is a O/E Land Rover NAS step, and thanks for the picture, that explains a lot. The only difference is that mine's fitted to my Td5 90. Cheers
The step in your first pic above is a genuine parts step as well - it doesn't have any brackets that go under the rear cross member so I'd agree that it should fit. John
2011 Tdci 110 CSW XS
Post #232025 1st May 2013 3:40pm
BigWheels
I will get the Mantec as I have a NAS step too. Are these guards corrosion resistant both sides? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #232327 2nd May 2013 9:55pm
BigWheels
I have a NAS step, & wondered if Paddock's own guard http://www.paddockspares.com/pm748-def-90-...steel.html would fit a 08 Puma with the step. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #248887 3rd Jul 2013 11:39pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'd be interested in knowing that too, if you find out pls let me know Wink
Post #248903 4th Jul 2013 7:20am
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
The manyec one does fit with the drop plate towing gear if you modify the guard as i found out last year when i fitted mine. from memory it required about 1" from each side to be removed to enable the support bars to be fitted 2004 TD5 Defender 90 xs station wagon
Post #248929 4th Jul 2013 9:05am
Lambley
Cheers, did you just cut off the excess with a grinder? Have you got a picture of it you could post please?
Post #248932 4th Jul 2013 9:09am
johnszs
Yes i used a 115mm grinder much to the disproval of neighbours Whistle
I will get the pics for you shortly 2004 TD5 Defender 90 xs station wagon
Post #249073 4th Jul 2013 7:13pm
johnszs
I hope these help
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2004 TD5 Defender 90 xs station wagon
Post #249355 5th Jul 2013 7:26pm
Lambley
Thanks John, I thought you were fitting one with an NAS step though? thanks for the pictures anyway mate.
Post #249446 5th Jul 2013 10:40pm
Page 2 of 2 <12
