![]() | Home > Puma (Tdci) > Gear lever rattle |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
Hi there
Do any of you have a bit of a gear lever rattle, especially when the engine is at lower revs (1700-2100) in 6th under a bit of strain (mostly going up inclines, etc). Is this normal? What's the cause? Cheers |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2060 ![]() ![]() |
Yes mine does this as well.
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 671 ![]() ![]() ![]() |
Guys,
Had the same problem: http://www.defender2.net/forum/topic1433.html New gear stick assembly solved the problem - warranty work. Cheers Ian |
Thanks for this - is that a big job? Do you believe there would be long term expensive damage if not corrected? Cheers |
Not a big job, just get it done under warranty
I'm wondering if they don't all do it (at least a little)?
I remember reading in the Owners Manual how important it is not to "hold" the gear lever - maybe there's supposed to be some movement? |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
also had the same, I did complain about it but they never said on the repair sheet that they attended to it.
That being said, it has not yet re-occurred although it only happened on a very long haul once everything is nice and hot. I will be testing mine again in a few weeks on a trip into the mountains again ![]() |
well, i took it in to the dealer and they replaced the gear lever assembly, and now it is so much better!
Malcolm Member Since: 17 Sep 2008 Location: Durban Posts: 10 ![]() ![]() ![]() |
I get a humming noise when going up hills in 6th. It seems to" drone" but I can't seem to locate where the noise is comming from. Ralton, do you get yours serviced at LR Durban or Umhlanga as I reported it and nothing was done.
Thanks, Malcolm Ex 2008 Puma 90 2012 Puma 110 |
I use Umhlanga.... Cheers |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 ![]() ![]() ![]() |
Having the same problem especially when speeding up it rattles, bought the issue up with my dealer while my car is in the LR garage, going to repair the rattle and its covered under warranty.
![]() '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
