![]() | Home > Puma (Tdci) > Engine misfire |
See the left external mirror (exhaust side). if you can see smoke when the problem appears, 99% the cause is the EGR valve..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 589 ![]() ![]() ![]() |
Hey Daniele! I do not think I've ever seen smoke. Glad you say the EGR might be a possible cause because I did mention the EGR valve to the dealer, who promptly replied that it would raise an ECU error and set the MIL on (the logic of the dealer is no MIL so no error, therefore no problem, ie I am not sure he believes me ![]() Problem, there no other dealer in the area ![]() |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Mine's going back in for a similar problem. Fortunately my MIL did come on for a couple of days. Lets see what they say. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
mine does it too, with black smoke if i hold it at about 2200rpm...
What is an EGR?, what does it do? How bad is it if left alone? etc... Cheers, |
just checked again, there really is no smoke that I can see in my case.
I can't see smoke either.
My guess is it's something in either the fuel metering valve, the fuel pressure relief valve or the High Pressure rail control valve. All have had dealer-notification issues logged with LR. The HPR control valve, especially is the one that is most likely. The recall notice is: "When driving following a cold engine start where the engine coolant temperature is <5>35° and a gear change is made at an engine speed of >2000rpm there is a possibility that the High Pressure rail control valve can stick and cause high rail pressure, which trips a diagnostic, relieves the rail pressure causing the customer to see an engine Malfunction Indicator Lamp (MIL) light on with restricted performance and P1169 and/or P0089 Diagnostic Trouble Code (DTC) stored in the Powertrain Control Module (PCM)." Their solution - put the engine patch in. However, they've either not done it (when they say they had) or they've done it incorrectly because mine still has these symptoms. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Ralton. The EGR refers to the Exhaust Gas Recirculation valve. It's a trick to reduce emissions by feeding the exhaust gasses back into the intake. However, it has to be precisely controlled because it has an effect on quality and quantity of air getting to the engine. If the valve sticks then it runs out range for the ECU and you get rough performance (is my understanding). Some people have blanked off the EGR to get more power (better quality air?) but they've encountered illuminated MIL lights as the engine thinks it is running out of tune. Black smoke out the back does imply it is linked to the EGR - probably worth getting your dealer to look into it if it is still in warranty. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Thanks alantd
I have already taken it to my original dealer, but they updated the software (which didn't fix the problem). I have recently changed dealers, so will take it in for an oil change service in a about 5000km time and mention it to them... Cheers |
Problem still present, seems definitely related to the temperature, ie the car is a pleasure to drive when cold, at first start, and after a few minutes the problem appears, getting worse as the weather becomes warmer (well, that's my impression at least). But no smoke that I can see.
Took it twice to the dealer, found nothing (as there is no error logged in the ECU). So could the EGR be the problem (given that it seems to be temp. related) and if so, can the EGR have issues whereas no error is reported? And does anyone tried cleaning the EGR? How difficult is the job (if possible at all)? |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 672 ![]() ![]() ![]() |
I'm the same, no smoke though. Does it regularly when driving gently.
Spoke to Guava in Guildford today and they said they have seen the same on other Pumas.
They found that it was a small amount of water in the fuel filter. Mines going in for a service in the next 1000 miles so will update. ![]() |
Makes me think of this thread http://www.defender2.net/forum/topic2067.html but the VIN of mine is past the ones listed. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Also have this symptom but only when cold (Africa Cold) and dissappears when Eng temp is about 40'C.
No faults on the scangauge and not a puff of smoke. very slight lag/misfire so not worried as yet. |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 ![]() ![]() ![]() |
Did anyone get to the bottom of this? I have the same thing. Generally under gentle acceleration and splutters at c. 1900 rpm in 2nd just before I hit the powerband and shift ti 3rd. I have had a engine remap, performance filters put in and a new exhaust. Never happens when accelerating more aggressively - only when gentle.
