Home > Puma (Tdci) > BONNET HINGE RUBBER INSERTS
zs1sam
South Africa 2011 Defender 110 Puma 2.4 SW Alpine White
Noticed a loud knocking noise coming from the dash are especially when on corrugated roads. I've traced the source to excessive play on the bonnet hinges. It looks as if the rubber / plastic insert arount the hinge shaft has moved or is worn. Any tips / ideas how to replace or modify?
Sam
2011 110 Puma 2.4
Post #248276 2nd Jul 2013 9:31am
JWL
Years ago on my old 90 I took the bonnet off(that cured it!) and when I put it back I had cut some thin inner tube into strips, used pushbike tubes, and inserted them between the different components to cushion the noise.
Post #248277 2nd Jul 2013 9:37am
WarPig
Undo the nut on the bonnet stay and then lift the bonnet back almost against the windscreen and it will lift out. An extra pair of hands hepls here. The plastic inserts will remain within the bulkhead hinge and can be pushed out. Take note of exactly how they are positioned as the new ones need to go on exactly the same.
Post #248279 2nd Jul 2013 9:39am
zs1sam
Thanks to both of you for the advice.
Sam
Post #248281 2nd Jul 2013 9:45am
LR90XS2011
better still buy some NAK hinges off Leeds or directly and everything is much better DEFENDER 90 TDCI XS,
Post #248460 2nd Jul 2013 8:07pm
