|  | Home > Technical > Rear Lower Shock Bushes |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      |
 I'm looking for some of the above as I noticed today that one of my bushes is a bit worn.
 I've found part number RNF100090L, but everywhere I look, it says they are for up to 2007. I've got a puma 110 and can't seem to find any. Anyone know if these do actually fit a Puma? Thanks Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  30th Jun 2013 2:06pm |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527    | RNF100090L is correct part number for lower rear shock bushes for your 110 | ||
|  30th Jun 2013 2:13pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Have you considered polybushes? A thread less than 24 hours old.......    http://www.defender2.net/forum/topic21477.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  30th Jun 2013 3:12pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | I did consider a Poly conversion, but I do a lot of road driving so was thinking about the increased stiffness. Craig Rogers
|  1st Jul 2013 1:07pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | Polybush do different variants for different conditions. I got an advisory on my MOT for mine and it is something I myself need to look at. I have heard the longevity of polybushes is worth the spend.
|  1st Jul 2013 1:11pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      |  Yeah, was just looking at the Dynamic Full kit - http://www.lrparts.net/defender-from-2002-...e-kit.html Looks pretty decent. I think I'll have a failure next month on mine as one of the lower bushes is a bit loose. In fact, decent question? What are peoples previous choices? Performance, Comfort or Dynamic? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  1st Jul 2013 1:13pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | I suppose it depends on interpretation of the words performance, dynamic etc. Ultimately mine are 'worn' and need replacing and I shall probably go for performance as I like that word. Mine is road use only and I suppose it doesn't really matter so much?
     I too was considering a full kit but bu993r it I'll replace just the shock bushes for the time being as I have worked quite a lot on the truck recently and don't need to bog myself down with anymore tinkering that doesn't need doing! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  1st Jul 2013 1:23pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Glad I'm not the only one thinking that.
 I'm going to just do the rear shocks to start with. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  1st Jul 2013 1:24pm |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610      | My need isn't as great as your but if you go ahead let me know please where you get them from, how the fit goes and of course what type? Be very interested to hear......
 Thanks.....  If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! | ||
|  1st Jul 2013 1:29pm |
| Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230    | Must be a common failing, mine are shot and in need ASAP, I was aware when I purchased too but thought they'd last a little more | ||
|  1st Jul 2013 4:21pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Must be a common thing then........
 Still undecided to just get standard for pennies or upgraded for a fair bit more. I away for most of this week so I'll worry about it when I'm back!  Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  1st Jul 2013 4:24pm |
| Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230    | Mine is also an advisory from March, so I better get them looked at pronto.  I'm going to Polybush all mine as I go along, I'm not going to rush but replace methodically as I need to.
 Any advice on type as there is three types, Performance/Dynamic/Comfort. My DC doesn't carry weight, but does haul the Sankey but really need advice on which would suit me. Don't want to bounce any more than I am already  | ||
|  1st Jul 2013 4:34pm |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Well I've decided to go for the Dynamic Polybush set for the rear shocks.
 I've emailed Polybush so hope to get an answer soon, but does anyone know if "Kit 12" does both shocks or do I need two of them? At £29.50 I'd expect it to be both shocks. http://www.polybush.co.uk/shop/view/7_2002...der_(2002) Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  10th Jul 2013 10:59am |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | "Kit 12" does indeed contain the bushes for both rear shocks.
 After deciding against them and going just for Genuine lower bushes, I decided that if I'm doing the lowers I may as well do the uppers. So I changed my mind back and have purchased the Dynamic version of Kit 12. Hopefully, I'll get around to fitting them this weekend. I'll let you know how I get on. Oh and if anyone wants a set of these...... > http://www.lrspareparts.com/eshop/bush-oe-quality.html < I purchased a set of 4 that cost £6.46 including delivery. Happy for £5 inc delivery. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  16th Jul 2013 9:23am |
| Posting Rules
