![]() | Home > Maintenance & Modifications > V8 in a TDCI |
| Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353
To those that have done it (or know about it) how complex is putting a V8 (let's assume a GM LS3) into a Puma based Defender? Is there a specific transmission and driveshaft upgrade etc....
Just wondering Stu |
| tacr2man Member Since: 02 Oct 2008 Location: J10 M40 Posts: 20 |
You must have a need to buy lots of petrol, as from experience they get thru it at an alarming rate (well in my110 it does) So i have just pulled it and am fitting a diesel, but not the dismal landrover defender options , a BMW 3litre , which will give the V8 performance without the fuel penalty.
If your deadset on a V8 then would suggest auto behind it , as the manuals (apart fromLt85) will be marginal on dealing with it for any length of time JMHO |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
i had more pleasure from a remapped td5 with sports exhaust than i did from my old 50th anniversay with a blueprinted 5 litre v8.
sometimes the grass is not always greener on the other side |
| All times are GMT |
