![]() | Home > Technical > 300tdi re map |
| camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3416
Unfortunately, there isn't an ECU to remap
You can go with a bigger intercooler and uprated pump to get up to around 140bhp ![]() |
| RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596
First make sure your engine is in tip top condition. Oil, all the filters and check timing is right.
Then remove egr valve if it has one. Put a de cat pipe on if needed. Buy a better intercooler then your new intercooler will come with instructions on how to tweak the fuelling. It does make a fair bit of difference but if your engine isn't right in the first place spend your money on making it run well. Sometimes it's a poorly running engine that makes you think you need to boost the power. The 300tdi needs servicing every 6000 miles. |
| Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
OK, thought as much but good to get confirmation.
I'm actually very happy with the engine at the moment, already has EGR blanking plate and decat pipe. It's been regularly serviced but I'll check the air filtre just in case. It had a splash of 2SO in the tank at the weekend, so it'll be interesting to see if there's any difference in smoothness tonight when I use her. Thanks |
Sorry teaching you to suck lemons there.
Mate of mine is always messing with his 300 but seems not to bother with the maintenance sheet. Just fix when broke. He has a better intercooler but has to back the fuel right off to get through mot. |
Not at all, always lots of new info on here and I have a lot to learn about my new toy!
Thanks for the info... |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480
https://www.defender2.net/gallery/albums/u..._Rev_2.pdf
should all be explained above. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks James, an excellent read. I'll have to go through that a few times to fully understand it but well worth the effort I'm sure!
feel free to post up once you have digested it. Cheers
| adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1389
fit one of our big turbo's...........
