![]() | Home > Technical > Proximity alarms on a 2012 defender...help needed |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
What, like those annoying ones that used to shout "WARNING.... MOVE AWAY FROM THIS VEHICLE, IT IS ALARMED" whenever a fox wandered past...
adyb Member Since: 06 Jun 2010 Location: Nottingham Posts: 23 ![]() ![]() |
Yep, one of those ! Seriously though, there are some that apparently go off when you are very close and not just walking within ten feet....hence the request to see if anyone has a food reliable one that works well ? If it had got one on it they wouldn't have managed to sever the main wiring loom !
Yeah, jesting aside, The last one of those talking alarms I ever saw was back in the 90's; i'm sure technology has moved on in leaps and bounds now so that proximity and false alarms are much better controlled.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6015 ![]() ![]() ![]() |
Not sure how difficult it would be, but would it be possible to put a micro-switch on the lock on the inside of the door to monitor someone pressing the button (i.e checking if a door is locked) and link this to a separate alarm. I guess this could also be linked up to the bonnet and also setup inside the door frames as well? 1999 Defender TD5 110
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 ![]() ![]() |
How close is too close? What happens if you park it in a car park and someone gets out of their car next to you?
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 ![]() ![]() |
I was thinking the same, something that chirps or whatever the expression is when someone is close....an audible warning.
Like this? |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
Clifford still do a proximity alarm and cobra also.
Main problem is u will have 2 transponders unless you disable the lr unit |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Not always.... You can use an output from the 10AS to control the aftermarket alarm. http://www.mobilecentre.co.uk/index.php?ma...0781b07cc5 This is exactly what this one does. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
