Home > Technical > Front wings
Front wings
Can anyone tell me if there is any difference between a late Td5 front wing assembly and an early Puma? I mean as far as the panels themselves are concerned not the adornments like lights, wiring, plastic bits, etc. The panels I'm interested in are the outer and inner wing, the top panel, and the front (headlamp) panel assembly.
Thanks!
Post #246680 25th Jun 2013 6:44pm
puma
side wing:
RH ASB710260
LH ASB710270
front panel
RH ASW710140
LH ASW710150
Headlamp panel:
RH ASW710120
LH ASW710130
Whole "top/front/headlight panel"
RH ASB710200
LH ASB710210
Inner wing:
RH AWJ710430 (minus sound insulation) AWJ710420 w/sound
LH AWJ710460 (minus sound insulation) AWJ710470 w/sound
Td5
sie wing:
RH RTC6351
LH RTC6350
front panel
RH ASW710140
LH ASW710150 (as per puma)
Headlamp panel:
RH ASW710120
LH ASW710130 (as per puma)
RH ASB710200
LH ASB710210 (as per puma)
Inner wing:
LH AWJ710460 (minus sound insulation) As per puma
Just seems to be the outer panel that has a different part number. Don't know what the physical difference is though... they seem to look the same.
Post #246724 25th Jun 2013 9:16pm
Wow! Thank you, five star comprehensive answer!
The outer panel ironically is the one I most expected to be the same.
Post #246805 25th Jun 2013 11:01pm
No wories. I was playing with the new microcat last night anyway so it only took minutes.
For a laugh... the new 2014 RRS stripped 5.0 V8 engine, costs Ģ13600 ish... that's what I paid for my new 90 in 1992!
Post #246839 26th Jun 2013 6:10am
Just in case anyone else is wondering what is the difference between an Td5 and Puma wing outer panel, further enquiries lead me to believe that the only difference is the shape and size of the ole for the indicator repeater lamp. On the Td5 it is a square-ish hole, and on the Puma it is a rectangular slot. Other than that there appears to be no difference between ASB710270 (Puma) and ASW710150 (Td5) on the n/s, and the equivalents on the o/s.
Post #248361 2nd Jul 2013 2:10pm
Hmmmm.... microcat shows the repeater lamp on the late Td5's to be the same as puma
Post #248405 2nd Jul 2013 4:13pm
Well, in that case I'm baffled!
Post #248424 2nd Jul 2013 6:02pm
landybehr
my MY12 front panel has another hole underneath the headlamp. I have no idea what it is for. I wasnīt aware of it until I removed the plastic headlamp/indicator/position-light - surround. Itīs approximately 3-4cm big if my guess out of memory works well.
I havenīt heard the TD5 have such a hole. If all plastic is removed thereīs only the rectangular (ventilation) hole midway between indicator and position-lamp
Post #248556 2nd Jul 2013 10:17pm
Interesting, but according to Microcat it is only the wing outer panel which is different - all the others are apparently the same!
The mystery deepens ...
Post #248600 2nd Jul 2013 11:45pm
GUM97
Ah, I believe (don't hold me to this) that this is for in built DRLs. (A trader at the Harrogate show told me this) An engine to TDi for!
Post #248748 3rd Jul 2013 4:35pm
grafty99
TD5 and Puma side repeaters are definitely the same Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #248783 3rd Jul 2013 7:33pm
