Home > Puma (Tdci) > 08 Plate, 22000 miles and it throws a diff out!
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Raging!
The connecting rid inside the pin broke today and the diff siezed shut with all the wee bits.
Spent the night reading up in atb and recon diffs from ashcroft. Which one should i go for? for �60 extra i can get the atb Rolling Eyes
I have old diffs lying about but would prefer a new/recon one for the road car. 90% road 10% the other stuff Razz
What would you guys do? William
Post #245451 21st Jun 2013 8:46pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
If its the front put a locker in if its the back put an atb
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #245461 21st Jun 2013 9:41pm
jst
Ashcroft ATB low pinion if rear
front another 4 pin but from Ashcroft. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #245466 21st Jun 2013 10:01pm
I'm guessing it's the usual problem of a 2-pinion diff failing on an early Puma.
Irrespective of which axle, fit an Ashcroft ATB. It's cheaper than a genuine parts replacement (which will be 4 pinion now anyway) but much stronger, as well as the traction advantages of an ATB. Works perfectly in either axle with no ill-effects on steering if in front axle. If you want an even stronger diff get an Ashcroft HD ring and pinion fitted, but be aware it is likely to whine a bit under certain driving conditions.
Post #245471 21st Jun 2013 10:27pm
william8
Just paid for my atb diff from paddocks(Ashcroft isn't open at weekends. Sad hopefully get it on Monday or Tuesday at the latest.
I still can't believe at 22000 miles a diff could blow! Just as we'll I was at the house at the time Smile William
Post #245532 22nd Jun 2013 11:04am
jst
an ashcroft ones from paddocks? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #246528 25th Jun 2013 9:00am
x-isle
http://www.paddockspares.com/ashcroft-limited-slip-diff-atb.html Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #246531 25th Jun 2013 9:20am
william8
I would have bought from Ashcroft direct but they weren't open at the weekend and I wanted to try and get it dispatched on Saturday. Hopefully it comes today and ill post a few photos and opinions on it Smile William
Post #246534 25th Jun 2013 9:44am
