![]() | Home > Puma (Tdci) > Puma loss of power and temp needle into red |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
Sounds like you are gunning it in 6th and the ECU is cutting power to prevent damage to the engine.
Lots of SaFas had this issue as well, cured by fitting a bigger intercooler. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Check the main relay under the driver seat Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 ![]() ![]() |
[quote="dgardel"]Check the main relay under the driver seat[/quote]
There is no relay under my driver seat Naks: what's the meaning of SaFas .....if I decide to change my intercooler, do you know where near Capetown et what price? Now, my car is stored by Duncan, African Overlander in Stellenboch |
[quote="Mongolia"]
SaFas: South Africans ![]() All SaFas get their intercooler from the UK, usually from Allisport or AliveTuning, the local products are just not goof enough. BTW, I live in Stellenbosch. If you want to see a Puma with BAS remap + Allisport intercooler, give me a shout ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Sorry you are LHD ![]() ![]() ![]() Passenger seat
there are (depending if your car have ABS or not) it is the 1st (w/o ABS) or the 2nd (with ABS). Check the socket contacts (they must be solid) and the relay teperature after 10-15 min of drive. When the water temp. indicator is going to the RED zone, normanlly it is a problem "main relay" related. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Should be, but the strange things is the Water temp on RED (comon on main relay related failure) with normal H2O real temp Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
SaFas: South Africans ;)
All SaFas get their intercooler from the UK, usually from Allisport or AliveTuning, the local products are just not goof enough. BTW, I live in Stellenbosch. If you want to see a Puma with BAS remap + Allisport intercooler, give me a shout :thumbsup:[/quote] Thanks Naks Now i'm stored in Joburg but I wil be in Stellenbosch next september So, I wil shout you to see your car |
[quote="dgardel"][quote="Naks"]Sounds like you are gunning it in 6th and the ECU is cutting power to prevent damage to the engine.
Lots of SaFas had this issue as well, cured by fitting a bigger intercooler.[/quote] Should be, but the strange things is the Water temp on RED (comon on main relay related failure) with normal H2O real temp[/quote] Yes, it occurs when I'm gunning on 6th but why my water temp on red ? and how to know the real water temp? I think there is only one sensor CHT on the back of the engine cylinderhead |
It is an electric problem related!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Don't gun it in 6th when towing uphill, rather gear down. The only way to know the coolant temp is to fit a Madman-type engine monitoring system or read it off with a Scangauge/Ultragauge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
Mongolia,
I've experienced both the intercooler and relay issues discussed above. If I was travelling up long inclines in 6th gear at altitudes over 1,000m above sea level in warm weather (30+ degrees) the vehicle would go into limp mode. It would cut back power and I wasn't able to get the revs over 2,200 rpm in 6th and 2,500 in 5th if I geared down. The temperature gauge would not move and no MIL light came on, nor were there any fault codes stored. The only solution at the time was to throttle back and take it slowly. I fitted a new intercooler 6 months ago and the problem hasn't resurfaced. The relay issue would happen at any time, even just after start up. The temp needle would shoot off into the red and the vehicle would cut out. This got progressively worse over a couple of weeks, until Land Rover replaced the relay. They diagnosed the fault quickly so maybe it stored a fault in the ECU, but I can't say that for certain. Replacing the relay is certainly going to be the cheaper option, but it may not be the cause of your problems. The intercooler issue is known to Land Rover South Africa, but they are of the opinion that the standard intercooler is good enough - there are plenty of us who disagree, including workshop managers, who ostensibly work for LRSA through their franchises. You need to be very clear on the conditions in which your limp mode occurred, if it was random have a look at the relay, but if it was hot and at altitude and the vehicle was under strain, the intercooler may well be your problem. PS. I imported my intercooler from Allisport in the UK, but there is a local version (the core is made in Europe) for sale, which is significantly cheaper. |
bvandyk Member Since: 03 Sep 2012 Location: South Africa Posts: 49 ![]() |
Yeah, the local version is R4600 at the moment. |
[color=red]Don't gun it in 6th when towing uphill, rather gear down.
The only way to know the coolant temp is to fit a Madman-type engine monitoring system or read it off with a Scangauge/Ultragauge[/color][/quote] Hi Nak's Currently, I'm still in France but I come to Stellenbosch on September 19 and I have to get my Defender from Duncan (African Overlander), where it is stored for 3 weeks. I still have my issue of power loss with needle temperature which rises rapidly in red and go into limp mode. It would not be too disturbing if it is only when this happens, my coolant level go lower and I have to add about 1/2 liter of liquid. So I think may be a head gasket issue? Would you know about Capetown: - A good diesel mechanic who could check my injectors (they are 170000km)? - A good garage that could check this head gasket issue and if necessary change it? In advance, I thank you for your help and sorry for my bad English. Regards Gerard |
Mongolia,
Yeah, sounds like a head gasket issue if you are losing coolant. Close to Stellenbosch I would go to Schalk Burger 4x4 (+27 21 883 4465). In Cape Town itself, there are few good indies: LR Services, British 4x4, it would help if you let me know where exactly you will be based. Vous m'appelez quand vous arriver � Stellenbosch, je vous donne mon portable par PM ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
