![]() | Home > Maintenance & Modifications > 110 DC spare wheel mount |
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
Like the 130 ?
Can you post a pic of the bracket you made? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230
I need to do something with my Spare also, tucked against the tub headboard takes up so much room.
| ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777
When it's a bit less busy in the tub I'll get some pictures |
It's a worth while mod and how it should be from the factory. Makes the rear tub a lot more useable. |
thanks. When you can... It looks like a great mod! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
+1 for the photos please.
Hopefully get the camera in there this weekend.
@ supacat, where in west yorks are you? |
PM sent.
Click image to enlarge |
Managed to get a bike lock around the bracket and through the spare for better security as the locking wheel nut is worse than a normal wheel nut.
That's quite an elegant solution and certainly food for thought over putting the spare on an external wheel carrier.
Out of interest did you look at or consider the OEM recessed tray arrangement that's available? |
I was told about the tray but didn't fancy carving the wheel boxes and thought this was simplest solution. I am surprised the DC has the sloping wheel boxes and not the square type like in the HT.
I didn't consider swing away as it restricts loading or else I would hae got a Ute |
Hi
Great! Did you fit any reinforcement bracket/plate under the wheel arch? Or on the edge where you have those screws?
don't see one since the SIII 109... Do you have any pics or the part number for that item? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| All times are GMT |
