Home > In Car Electronics > Connecting a secondary fuse panel
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I've got a 12 way fuse panel with a negative buss bar that I want to install in the battery compartment of my MY13 Defender. Connecting up the +ve side will be easy but the negative terminal on the battery seems to have a battery connector designed to not mke it easy to connect up the -ve buss bar on the fuse panel. Where should I connect the -ve to? Any suggestions? 2013 Aintree Green 110 Station Wagon SX
Post #245851 23rd Jun 2013 11:23am
K9F
Does your negative terminal not have a bolt in it that you can connect a ring tongue terminal to? If not replace it for one that does! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #245852 23rd Jun 2013 11:24am
TheWarden
No, it doesn't - that's what surprised me.... getting it replaced might be the best option at the moment 2013 Aintree Green 110 Station Wagon SX
Post #245855 23rd Jun 2013 11:35am
K9F
You're not a million miles from me and I am a sparky. If you need any auxilliary leads made or crimping I have the heavy-duty crimps together with the crimp tool and some 10mm and 6mm cable left over from my own fusebox installation project in the garage. Let me know if I can be of any assistance. Will have to be weekend job though.
I fitted mine in the battery compartment too with a 60 amp megafuse. Details in the link below the picture.
http://www.defender2.net/forum/topic20439.html?highlight=fusebox If you go through life with your head in the sand....all people will see is an ar5e!!
Post #245856 23rd Jun 2013 11:44am
TheWarden
What about running the negative out of the battery box and connecting to the same point on the back of the gearbox as the battery -ve as a short term solution until I do the whole dual battery thing? 2013 Aintree Green 110 Station Wagon SX
Post #245872 23rd Jun 2013 12:43pm
MartinK
I did that (almost). I put the new negative to the point where the earth bolts to the chassis...and replaced the original nut & bolt with stainless items to reduce the rish of corrosion causing a bad earth in the future.
If you follow the thick earth lead under the car you wll see it splits, one end earths on the chassis (the one I used) and the other earths to the back of the motor/gearbox Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #245881 23rd Jun 2013 1:42pm
clwlaptop
Wales 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Just thought I'd add some photos of my 2013 battery box for info. Can see +ve and -ve terminals
Post #246150 24th Jun 2013 7:30am
Replace the negative battery lead connector with something more conventional and more useful.
Post #246175 24th Jun 2013 9:08am
The battery box looks the same as 2.4's
I crimped a new ring terminal to the factory earth and ran it to a busbar, I then used new leads from the two battery earth posts to the bus bar
I then ran a 70mm positive (top left) through a mega fuse from the second battery through to a positive bus bar under the drivers seat
Post #246176 24th Jun 2013 9:14am
