Home > Maintenance & Modifications > halfords transfer box oil
Caterham
hi,
can anyone recommend a top up / replacement oil for the transfer box from halfords?
I presume its a case of topping up to the fill plug?
Post #245737 22nd Jun 2013 8:54pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
For transfer box on a 2.4 Puma you need SAE 75W/90 GL-4/5
At Halfords its 9.99 for a litre
http://www.halfords.com/webapp/wcs/stores/...yId_255220
Same can be had here for less: - £20 for 5 litres at Euro car parts
http://www.eurocarparts.com/ecp/p/car-acce...mp;cc5_868
Also try Oopie Oils
You will need roughly 2.3 litres ( if replacing)
Post #245749 22nd Jun 2013 9:27pm
Caterham
thanks kmac.
is the halfords ok as a top up (ie mix it with existing?)
thanks v much.
Post #245752 22nd Jun 2013 9:44pm
kmac
The Halfords stuff should be fine to top up with. There are no issues with mixing GL4 and GL5
Post #245754 22nd Jun 2013 9:47pm
Caterham
thanks very much.
and fill it till it comes out of the fill hole?
Thumbs Up
Post #245757 22nd Jun 2013 9:52pm
kmac
If topping up not much else you can do. Remember do not open the drain hole until you are sure you can open th e top up hole Smile
The top up hole needs to be closed to 35Nm if you have a torque wrench
Useful video here http://www.defender2.net/forum/topic15515....vice+video
You will need something to pump the oil in - check video from about 4.40 mins in
Post #245761 22nd Jun 2013 10:00pm
Caterham
what more can I say ....
Thumbs Up
Post #245771 22nd Jun 2013 10:34pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
If you don't have a pump, find a suitable piece of hose long enough to reach from the TX box to up the side of the door, cut the bottom of a plastic bottle, tape on the hose, put hose in TX box........ etc, have a container ready (clean) to pop the hose in when TX box is full. Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #245795 23rd Jun 2013 7:44am
Caterham
thanks. having had a good luck I'm hopeful that the short hose that comes on the 1 ltr bottles will suffice??
Post #245797 23rd Jun 2013 7:56am
As far as as I know, you don't fill it up to the hole, you need an exact amount ..
Post #245810 23rd Jun 2013 8:35am
Caterham
thanks bpman.....although it sounds like you're not quite sure ?
can anyone confirm if exact amount needs to be installed or whether the exact amount is what will fill it to the fill point?
many thanks.
Post #245819 23rd Jun 2013 9:09am
Happyoldgit
Top up the transfer box to the level of the filler plug. Main gearbox requires a specified amount. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #245825 23rd Jun 2013 9:34am
Caterham
thanks very much Steve.
right - I'm armed and dangerous.
prop is out - got the oil, grease gun and brake cleaner.....
1 mug of tea and its business time !!
check / clean handbrake drum. grease as many nipples as I can find. then re-instate followed by a top up on the transfer box (checking how much oil its lost in the last few months / 3k miles......??
(suspect another / call warranty claim might be in the making but lets wait and see).
Thumbs Up (thanks all).
Post #245830 23rd Jun 2013 9:50am
Happyoldgit
You'll probably find the actual level is a bit below the filler when you undo the plug, just stick your little finger in to check - but don't get it stuck as that might be embarrassing Rolling with laughter Steve.
Post #245832 23rd Jun 2013 9:56am
Caterham
I think I'll give the little finger thing a miss Very Happy
assuming I can get the oil in I'm might be tempted to do a full oil change because I think the drain plug needs to come out as its leaking oil.
assuming all is ok I suspect the best thing to do will be put some ptfe tape on it. ??
what do you reckon / or should it be a warranty call ??
thanks.
Post #245835 23rd Jun 2013 10:02am
