Home > Maintenance & Modifications > RRC hand brake on a puma ?
Has anyone fitted a RRC handbrake to a puma ?
This was a modification I did to my td5 110, its basically relocating the hand brake to the side of the cubby, makes for easier application of the hand brake. Only the hand brake needs to be changed on a td5, the cable just needs adjusting - thats it.
I got the initial idea from here:
http://www.reedx.net/landrover/mods/handbrake/index.htm
not a great photo but you can see it installed here, it's a little higher and back towards the cubby
Post #245570 22nd Jun 2013 2:55pm
Luismi
Spain 2004 Defender 110 Td5 SW Alpine White
This going to my to do list Steve
now your leg don't lay on the handbrake isn't ?
Post #245612 22nd Jun 2013 6:00pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
RRC handbrake mod
I changed the handbrake lever for an RRC one a couple of years ago, on my 09 Puma 90 xs. It’s so much better relocated next to the cubby box. I set it on an aluminium plinth bolted through the floor panel, using the original brake cable set at a different angle to connect up with the new linkage. I can now rest my leg in comfort while driving. I used the original gator over the new unit. It looks quite good in the new position. When it went in for its first MOT the tester thought it was standard fit because it is an XS model, I just agreed. Also the hole left by removing the old lever was blanked off with an aluminium plate using the two tapped holes that held the original lever on.
Post #245637 22nd Jun 2013 7:25pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Its on my list of things to do as well. If anyone is interested the part number is NTC2794.
Regards,
Mark
Post #245649 22nd Jun 2013 7:46pm
A disco handbrake lever here on eblag
Looks the same as a RRC one... £20 too.
Post #245843 23rd Jun 2013 11:11am
mk1collector
Thumbs Up thanks for posting this! My handbrake has been annoying me for years on long journeys so I've just swapped mine for a disco 1 handbrake and it only took about 2 1/2 hours Mr. Green
Ray
Post #248094 1st Jul 2013 5:45pm
Did you use a lever the same as the one in the link I posted above?
(If so, I know where I can get one for mine)
Post #248099 1st Jul 2013 6:02pm
mk1collector
Yep Thumbs Up
Ray
Post #248103 1st Jul 2013 6:17pm
cool.
looks wierd with two handbrake levers!
Post #248104 1st Jul 2013 6:21pm
mk1collector
It did a bit! But not anymore Mr. Green
Ray
Post #248106 1st Jul 2013 6:38pm
ibexman
I used a Discovery 2 handbrake Thumbs Up
Post #248107 1st Jul 2013 6:55pm
Are the D2 levers much different?
Post #248108 1st Jul 2013 6:56pm
ibexman
No Jim much the same as RRC
Post #248176 1st Jul 2013 10:10pm
ibexman
[quote="ibexman"]No Jim much the same as on the RRC plus side you can use the original rubber boot turned upside down e]
Post #248177 1st Jul 2013 10:11pm
