Home > Maintenance & Modifications > Fitted my NAS Rear Bumper, extended tow ball?
xtreme
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Sumatra Black
Hi
Just fitted a NAS rear bumper to allow me easier access plus extended tow bar mount was to help me mount my cycle carrier easier, but the vertical support on the Altera carrier still "just" snags the rear wheel making it difficult to lock back into place when it has been tilted down for access.
Can anyone recommend a tow ball that has a slightly longer "reach" - not needing height just distance from the vehicle? Alternatively will fit a spacer plate?
Thanks
Barrie
Post #243480 14th Jun 2013 8:54am
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
have fitted spacer behind tow ball 60mm or LONG EXTENDED NECK CAR AL-CO AKS ALKO TOW BALL TOWBALL COUPLING thing to watch LONG EXTENDED NECK tow ball is the load rating fond is place then looking for spacer for my van
TENT HIRE DIRECT
105A EDWARD STREET
WALSALL
TELE 01922 634808/632371
Post #243497 14th Jun 2013 9:47am
chrisb
United Kingdom 2012 Defender 110 Puma 2.4 XS CSW Santorini Black
I have the rear NAS type rear bumper. Attached to that is a Dixon Bate adjustable height bracket, and then tow bar.
Tows fine (General trailers upto about 2 tonnes) and bonus is the bike rack fits perfectly, just clearing the spare wheel.
Post #245457 21st Jun 2013 8:25pm
Exactly what I am about to do Thumbs Up
Post #245507 22nd Jun 2013 8:31am
DAZ110
Post #245525 22nd Jun 2013 9:18am
xtreme
Just to add my experience!
Nas now fitted plus standard tow ball, altera bike carrier just fits on with upright tight on spare tyre, but when slid out does not click into place/lock so need to extend further.
Tried Alko extended tow bar, despite being assured this extends outward it doesn't, only height.
Just ordered the 1 1/2" alloy extension to give the clearance!
Barrie
Post #245536 22nd Jun 2013 10:19am
DAZ110
Don't forget you might need longer bolts.
Post #245542 22nd Jun 2013 11:28am
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Hi
I have used this is the past
Allws you to move a standard tow-ball further outwards
Up for sale if anyone needs it as I now have one of these (also for Atera bike carrier)
Post #245710 22nd Jun 2013 8:17pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
What are the measurements and weight loading? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #245723 22nd Jun 2013 8:41pm
kmac
The one I'm currently using extends to 1700mm and can take nose weight of 100KGs
If using it to tow the manufacturer says max 2500KG towing load
The one I have for sale has same nose weight, but is just shorter 5 7/8" (so just under 6 inches) I installed a swing away spare wheel carrier so needed to extend out even more so moved to the other one. I have used it with 4 adult bikes on long motorway journeys with no problem. Don't know the towing weight of the smaller one. (I don't tow).
Pic below of the smaller one fitted
Post #245733 22nd Jun 2013 8:50pm
Interesting to know. I think others have posted that the rear step bumper is not best suited to towing as it leaves the towball too high for many standard trailers. Are you just using a standard D&B mount with it set on lowest setting or have you had to modify further?
Post #247549 29th Jun 2013 5:50am
