![]() | Home > Technical > Hawkeye or Lynx? |
Nanocom EVO? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
That could be added to the list, but then again it is over £100 more, can anyone justify a 3rd more in price? Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Maybe because it's recommended by this guy too perhaps?
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
does that justify £100 extra? Optimists say the glass is half full..
I wouldn't know myself but if I was in the market for a diagnostic tool on the basis of what both Pete and Daniele recommend that would be good enough for me personally.
Drop them a 'PM' you'll get a quicker answer. ![]() Treat every day as if it is your last....one day you will be right!! |
I just read the topic above this one, lot's of reading to be done to read all the links as well, nightshift again tonight, I'll read it all then
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Does this mean:- a) that a Nanocom Evo is not VIN-locked, and/or b) that a Nanocom Evo for Td5 will work on both Disco2 and Discovery? |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1320 ![]() ![]() ![]() |
They are not VIN locked but certainly model specific so you couldn't use a TD5 on a Disco
But a Disco2 Td5 Nanocom Evo should work on all Td5 Disco2's, and a Puma Defender one should work on all Puma Defenders?
Interesting info, many thanks! ![]() |
Correct |
For the Puma I'm not so sure the Nanocom is worth it - if its brand specific error codes you want a cheaper code reader such as Sealey VS8702 http://www.toolstop.co.uk/sealey-vs8702-eobd-code-reader-p57417
Now the Nanocom has no manual as such so maybe it has loads of other features that i don't know about..... |
