Home > Maintenance & Modifications > Rear crank oil seal - Engine or gearbox out?
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I have a fairly regular annoying oil leak from what must be the rear crank oil seal.
I have it in my mind that it will be easier to take the engine out as opposed to dropping the gearbox out.
Any opinions? Or anyone done the job?
Dave
Post #245215 20th Jun 2013 10:15pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Defo engine out, much easier to change the seal that way.
Post #245233 20th Jun 2013 10:57pm
familymad
Only on a series and yea, engine out was easier. I think yours will have. Removable gearbox cross member though? This will make the box out possibly easier?? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #245234 20th Jun 2013 10:58pm
dgardel
Italy
a first screaming:
Very black oil leak = Engine oil
Clear or brown oil leak = Gearbox oil (or clutch piston oil) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #245269 21st Jun 2013 8:06am
v8bobber
Thanks for your help, I was just trying to avoid the inevitable mess having to drain the coolant but realised shortly afterwards that i've got to drain the oil to get the sump off anyway so I may as well take the engine out.
Although it seems to be alot, it's not actually a massive amount. It'll have to wait a couple of weeks
Dave
Post #245485 22nd Jun 2013 12:25am
