Home > Puma (Tdci) > Weird thing happened today!!!!!!!
Cracka
2012 Defender 90 Puma 2.2 HT Fuji White
Well, I was chasing a small rattle (yeah I know, OCD) in the dash behind the instrument cluster in my '12 Puma. Couldn't find anything obvious so I thought I'd take the instrument cluster out and go for a drive to see if I could find it without that masking the sound.
Strangest thing, the car was very jerky (kangarooing so to speak) at slow speed, the throttle was responsive and there was no rev flare between gears and it had s--t loads of power right off the start, quite remarkable really. Maybe the cluster being disconnected alters the ecu.
Just thought I'd share that.........
No, I didn't find the bloody rattle either Big Cry
Edit:
When I put the cluster back in obviously the tripmeter had reset, which I expected, but when I switched to start the engine I had a the words 'oil service' show up in the window where the odometer/tripmeter are for about 3 seconds and then go to the normal odo/trip screen. It only did this for about 3 or 4 on/offs then disappeared.
Post #245047 20th Jun 2013 9:38am
The instrument cluster ECU and the engine ECU are in constant communication. The biggest wonder to me is that it ran at all without the instrument cluster connected!
It is actually probably not a good idea to run in this way for a whole range of reasons. I don't know what problems it will actually cause on a Defender, but on something like a Disco 2 you'd run the risk of the two odometer recorders getting out of step which will, I think, disable the vehicle until reset.
Post #245051 20th Jun 2013 9:43am
Cracka
You and me both, I didn't expect it to even start. I only drove about 2kms. When I put the cluster back in obviously the tripmeter had reset, which I expected, but when I switched to start the engine I had a the words 'oil service' show up in the window where the odometer/tripmeter are for about 3 seconds and then go to the normal odo/trip screen. It only did this for about 3 or 4 on/offs then disappeared. I forgot to put that in the original post.
Post #245059 20th Jun 2013 9:53am
Interesting and wierd!
Remember that the Ipack on the Puma Defender was lifted from Disco 3 and consequently is has many, many features which are not used on the Defender.
Post #245073 20th Jun 2013 11:01am
Cracka
Excuse my ignorance, what is the Ipack?
I'm guessing, but probably way off track, Instrument package maybe, I have seen the same cluster in the Freelander.
Post #245075 20th Jun 2013 11:07am
Ipack is the catchy modern buzzword lingo for the Instrument Pack (although I think LR spell it IPAC).
Post #245102 20th Jun 2013 1:34pm
Cracka
Aha so I had it right after all Wink thanks mate Thumbs Up
Post #245104 20th Jun 2013 1:44pm
