![]() | Home > Technical > Momentary Hiccup |
| LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233
Simon! Have had her out then?!!!
Have you had same issue? |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
No |
| Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171
Mine was doing the exact same thing. Points and condenser fixed it.........I don't think yours has these
Sorry cant help more Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
| Smurph Member Since: 29 May 2013 Location: Zimbabwe Posts: 27
Had a similar problem with a Td5 once, it was the accelerator potentiometer.
Just a quick update,
Had a check at dealers last month and only 1 error code came up : mechanic said he'd never seen it before (something to do with command module iirc). He updated software, which made it noticeably smoother and slighty quieter. Still occasional hiccups though... Did 1500 plus miles, fully loaded, on peage to Landrauvergne and it ran brilliantly at 80. No hiccups even at 36 C. Has hiccuped back here in uk recently though so wondered if it might be fuel related? I normally use basic diesel. |
