Home > Group Buys > 3rd run group buy for the integrated remote key
Page 8 of 9 <123456789>
Kyulandy
Germany 2010 Defender 90 Puma 2.4 SW Santorini Black
Grazie Daniele!!!!!!!!! Bow down
Key works perfect.
Bye Bye Ingo
Post #217163 8th Mar 2013 4:31pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Done mine. All good. The range is twice as great too.
Post #217355 9th Mar 2013 8:26am
Egghead
Big Cry I want one of these!
Post #218935 14th Mar 2013 10:51am
SGH
DO NOT buy one of these keys if you have the XENG steering lock shroud fitted or thinking of getting one.
Transponder in key will not communicate with coil that has to be repositioned to fit XENG shroud Sad
Post #218936 14th Mar 2013 10:58am
comandante
2007 Defender 90 Puma 2.4 SW Alpine White
Hello Daniele,
thanks for your effort.
After copying the key by the key service and coded by Nanocom, the indicator light flashed twice during unlocking and 4-times during locking, which is one time too much and indicates a weak battery. I measured the battery with 2.84 Volts and replaced it with an identical (CR1220) one. I placed the new battery positive pole upwards in.
Now neither the red lamp works while pressing a button nor am I able to lock or unlock. By the way I measured the new battery with 3.23 Volt.
What do I need to do now and why is the battery in a new key already low or empty?
Must the red light in the key iluminated, if I press a button?
Kind regards
Comandante
Post #219330 15th Mar 2013 7:40pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
comandante wrote:
Hello Daniele,
Mine does this too, didn't realise it meant the battery was weak!
Post #219368 15th Mar 2013 9:35pm
dgardel
Italy
yobbie wrote:
comandante wrote:
Hello Daniele,
wrong!
when the battery is low the lights not flashed at all.....
pag. 33 user manual (UK)
Mine fob (2 years old)have this sequence also (indicator light flashed twice during unlocking and 4-times during locking)
With "my" keyfob and certains AS10 SW version work like wrote but it is normal! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #219438 15th Mar 2013 11:53pm
yobbie
Thanks Daniele, thought it was ok as the range is much better than the old original one. Thumbs Up
Post #219471 16th Mar 2013 9:22am
SGH
Anyone have one of these using on a 2.2 ? Key works but only once to restart vehicle after stopping I have to lock vehicle with fob unlock then it will work ?
Post #229585 22nd Apr 2013 12:07pm
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
My 2.2 2013 refused the pod! It was not possible to pair the key with my car using the pod. Today I visited my dealer - after 15 min work everything works fine. No problem for my dealer to learn the new key to my car.
Det locker bleiben
Post #229635 22nd Apr 2013 3:54pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Late 2012, with 13 plate updates already in it and has had no issues. Just plugged the pod in, left it and then the key worked. No issues at all and a great integrated key ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #229638 22nd Apr 2013 4:38pm
Jim_Bean
I'd like one of these too!
Sounds great.
Post #244640 18th Jun 2013 3:14pm
Johnnyb0
I'd like one of these too, please is this still possible?
Post #252896 21st Jul 2013 10:18pm
johnnyd
Is one of these any good on my 1998 td5, I have an nnn000120 ecu, what is it capable of? Can I immobilise?
JD 2008 TDCi 2.4 XS CSW
Post #252906 21st Jul 2013 11:13pm
S92
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Is it still possible to purchase 2 keys and a programmer?
Post #271911 6th Oct 2013 9:56pm
