![]() | Home > 130 > Longrange tank for 130? |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Same 'dutch boat'?
![]() Light goes up every 530-550 km. I usually fil it up around 600 km, but I must say it can be annoying sometimes. Maybe that's because I did 900+ with a VW van. ![]() I've seen some tanks but I couldn't say I was pleased with the looks of it. |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 238 ![]() ![]() ![]() |
I tow a boat. Mange only around 400 Km on a tank... |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
There are side tanks with 75 Liter, under rear seat tank with 60 Liter and replacement tanks with 110, 130 or 160 Liters available. WANTED:
SII or SIII in max 1.5k |
kjmeijer Member Since: 09 Apr 2012 Location: Netherlands Posts: 84 ![]() ![]() ![]() |
I manage about 650 kilometers on a tank but almost no motorways and with the Alive Stage 1 tuning. 2021 Defender 110 D300 HSE
Juddy Member Since: 09 May 2013 Location: Queensland Posts: 63 ![]() ![]() ![]() |
I get around 580k from a full tank. 2010 Defender 130 HCPU
1991 110 RFSV PERENTIE www.landybitz.com.au |
wolley Member Since: 05 Jul 2013 Location: Centurion Posts: 5 ![]() ![]() |
i fitted a tank under the rear seat with a gravity fee to a second tank under the driver seat outside/under. then a dielsel pump to the mail tank. totals about 90lts extra 110 DC, 130 DC
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
I drive a 110 DC and can't get much more than that! 600 km...most times!
Are those available for 110's also? Where? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
130 tanks: I had it custom made - the marked does not offer much for 130's and the 130 design surprisingly does not allow easy customisation re fuel tanks. There is a 45lt tank design that fits in-line with the 110 (gravity feed in/out), which works well, and is sufficient for basic requirements (121 lt total). In case of the 110, I carried 4 x jerry cans on top for more serious trips and found that sufficient. My 130 design makes jerry cans redundant and solves the high centre point of gravity I had with the 110 110 DC, 130 DC
TJN Member Since: 03 Sep 2012 Location: Winchester Posts: 6 ![]() ![]() |
I have a140lt second tant that sit in the bed and gravity feeds into the main tank when i turn a tap. www.tektanks.com will make you a tank any size and shape you wnat. Really good they made my water tank.
RoyW Member Since: 30 Dec 2014 Location: Utrecht Posts: 9 ![]() ![]() |
Since you're live in the Netherlands you could take a look at fuel tanks of PSP Expeditioncampers. They can provide you with a 60 + 70 extra tank(s). They will be mounted to the chasis between the crossmembers.
Worth taking a look: http://www.psp-expeditioncampers.com/produ...zt130.html Good luck. Roy |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
A work of art here, but its 1500eu and its in France
http://www.outback-import.fr/en/product/3662845014627 |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Or up to 150 litres of fuel in one stainless steel tank from Nakatanenga here
1,195 Euro Brendan |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
I just fitted Nakatanenga's 130 l tank into my 130 this week. I honestly could not be happier with the finish of the part and it's fit. It took me six hours in total including lunch and clean-up, which I think would have gone quicker with a helper. I've only filled it with 90 liters so far because I want to ensure my fittings are tight and not leaking etc. I completely recommend these tanks.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
