![]() | Home > Puma (Tdci) > fitting spot lights |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 ![]() ![]() ![]() |
Think its white with blue test it with a test light first if not then its white with red best if you wire up with a switch as well to relay then if you don't need them on with full beam you can switch them off
![]() Dave |
dullbird Member Since: 25 Aug 2007 Location: sydney Posts: 87 ![]() ![]() ![]() |
hey thanks matey yes we have wired with a swtich etc its the law out here........ thanks again for your help YOU KNOW REHAB IS FOR QUITTERS!!!! |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Yep,, for memory, when i did mine, its the Blue/White behind the clocks California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
