Home > Puma (Tdci) > Hand brake light stays on intermittently on hill descent
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Was doing an offroad track that was up and down fairly steep slopes and the trail was about 1 hour, so there was fair use of the foot brake and engine braking. Some descents on low range 2nd gear drags the rev up to 3k. There was some point when the handbrake light lighted up. Is it the brake overheating or is it the engine braking?
I tried engaging and releasing the handbrake but it has no effect. I went away
When I roll it along without much engine brake or footbrake.
By the way I am on 110xs puma 2.2.
Post #244208 17th Jun 2013 2:39am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I believe the dashboard light comes on for 2 reasons:-
1. Handbrake ON.
2. Hydraulic brake fluid level LOW.
Have you checked the fluid level. With footbrakes on and steep descent the level may be such that it is just enough to trigger the fluid level sensor. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #244211 17th Jun 2013 5:28am
rustandoil
As Welsh Gas says, low fluid level....
Post #244212 17th Jun 2013 5:44am
ronwong
will check that and revert.
Post #244229 17th Jun 2013 8:52am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I would check the brake pads first...might be worn, and causes the brake fluid level to drop...
If the brake pads are not worn then it could be brake fluid level...
Or it could be a handbrake switch failure Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #244385 17th Jun 2013 6:28pm
stewalex1984
2012 Defender 110 Puma 2.2 USW Santorini Black
Hi, wondered if you got a solution to this?
Post #303490 30th Jan 2014 7:37pm
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
I had this issue and mentioned it in a previous thread on a new 110 DCPU XS.
The solenoid switch in the handbrake turned out to be faulty, so every time I went down a hill the light came on and flickered like a Censored .
The stealers replaced the solenoid switch and the issue went away. You may be fobbed off by being told the switch is not correctly aligned. They are so cheap and require abit of faffing with the hand brake gator off, they might aswell just replace it rather the potential of 2 visits Rolling Eyes
Post #303599 30th Jan 2014 10:52pm
mick
New pads will be needed
Post #303600 30th Jan 2014 10:55pm
MK
Same here. It is a LR. Puma 110" SW
Post #303606 30th Jan 2014 11:08pm
bear100
Had the same issue with mine and was told by stealer the abs plug/connecter was loose Shocked
worth a look
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #303608 30th Jan 2014 11:13pm
