![]() | Home > Technical > Wiper fuse blowing continuously! |
Faulty switch ??
Knowing how the light switches go I think I would start there. Also there is the park switch on the motor, if that starts to play up the wipers do strange things. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
It's just a matter of getting a handful of fuses and going through the circuit methodically. Pull the relay and fit a new fuse, turn on the ignition, does the fuse blow?
If so the fault is obviously before the relay. Refer to the diagrams and then find another suitable disconnect point and do the same again. Continually try to split the system in half until you nail down where the fault lies. ![]() Treat every day as if it is your last....one day you will be right!! |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
I have fitted a new stalk/switch but the fuse is still blowing.
Ill work my way through those steps above ![]() |
My bet is on a wiper wheel box seized
I'll check those. But they were replaced about 3 yrs ago. |
We're they replaced with genuine parts or aftermarket? I put two lots of aftermarket in mine before I bought genuine which turned out to be only a few quid more expensive
Splitpin Member Since: 07 May 2013 Location: Midlands Posts: 100 ![]() ![]() |
I have seen the wiper motor bearings seize also
They were aftermarket as I needed them in a rush.
