![]() | Home > Maintenance & Modifications > Need new discs, any recommendations? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20946 ![]() ![]() |
I'm currently running standard fit on my 90 Puma at the moment but recently had EBC Green stuff pads fitted and I'm very impressed. When it comes around to discs needing to be changed I personally will seriously be considering EBC discs.
![]() perhaps something to consider at least?.. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 868 ![]() ![]() ![]() |
I have been running EBC discs and Green stuff pads for over a year on my 110 DC with no problems.
A worthwhile upgrade in my view. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Are these vented discs with upgraded callipers? Is there a marked improvement with EBC discs & pads compared to standard? |
Haven't used discs yet but there is on pads alone from my point of view. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 352 ![]() ![]() |
What sort of price are they? What advantages do they actually offer? Proud owner 110 Utility XS Ex RR Sport HST V8 Ex Td5 90 |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I recommend Mintex. My local mechanic swears by them because they don't warp and they wear really well. In fact I only recently found out that they are OEM on Pumas (maybe all LR vehicles ?) Great value IMHO
Thanks for the advice. I ended up getting some Paddocks Performance (Proline?) solid drilled grooved discs, and some EBC Greenstuff pads
![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Let us know how you get on with them.
Will do. But bear in mind mines a 300tdi so probably a different braking experience than a Puma?
Going to be getting the wheel bearings changed as well. |
You can say that again ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
iPints Member Since: 15 Jun 2012 Location: SC Posts: 294 ![]() ![]() ![]() |
I have a 300tdi too, let me know how you get on as in seven years of ownership i have never had to change the brakes! ![]() |
Barring the effects of age, I don't think the brakes are significantly different, to be honest. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
My Puma has the OE & they are good enough to make the ABS kick in on some emergency stops. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2763 ![]() ![]() |
Surely as a 300Tdi 110 yours has vented discs as standard on the front? Or are these solid discs you've bought special extra thick ones to take account for that? As standard thickness solid discs won't fit where vented ones ought to go.
Drilled/grooved discs are a waste of time if you go off-road, they just fill with mud and grit and wear your pads down even quicker. Be alright for a road-only vehicle, though I'm not sure I see the benefit on a Land Rover. |
