![]() | Home > Technical > 2001 TD5 - all metric..? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
All metric will be fine,although i think the propshaft bolts may still be 9/16 AF. 2005 Td5 90 XS
Steve |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Hmm, I was thinking of buying the Halfords Pro set in metric, but might get the mixed set. Prop shaft might be one of the items that needs attention on the trail.
Thanks for the response. Cheers Simon |
Just buy a single 9/16 AF socket why pay for a load of others you may never use.Mind you a 7/16 is sometimes handy to hammer on to a rounded off 11mm. 2005 Td5 90 XS
Steve |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
You can get a specific prop shaft socket which makes the job easier. Getting normal sockets on can be a bit of pain.
Thanks...good ideas there....
