Home > Puma (Tdci) > Q225 - ENGINE CALIBRATION UPDATE |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
I googled it and got this thread as the first result: http://www.defender2.net/forum/post243609.html
er.....no idea. |
14th Jun 2013 7:06pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
It just outlines a 12MY software issue.
It depends on the software versions on the vehicle already. Two versions are of concern. One of the two requires just a software update with SDD. The second requires an oil and filter change as well as a software update. |
19th Jun 2013 9:50am |
Dealers will tell you exactly what it is and if it's applicable to your VIN!
Phone or pop down to Matfords.... http://www.matford.exeter.landrover.co.uk/ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Jun 2013 10:21am |
Software version CH12-14C204-AC is update + Oil and Filter + oil service rest
Software version CH12-14C204-AD is just a software update. SDD needs to be at DVD132.03 with up to date configuration files. VIN range is LD412477 to LD423910. Concerns: 1. Amber DPF light on and regen occurs too often (Hence oil change) 2. Driveline vibration or noise (Well it's a Defender FFS) 3. Hestiation on acceleration after previously backing off the throttle. PM me with an email address if you want more detail - TOPIx is copyright material so I can't post it on the forum. |
19th Jun 2013 11:18am |
