![]() | Home > Off Topic > PC modem cleaning |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Compressed air and a brush - small paint brush - is what I use to clean circuit boards and the insides of my PC. Also use the vacuum cleaner to catch the dust, otherwise it just heads back to where it came.
Static shouldn't be a bit issue, but I usually make sure I keep my hand earthed to the casing every now and again to discharge any possible static. Cheers Simon |
Isopropyl alcohol is also very good for cleaning electrical components if a good old brush and compressed air doesn't get it clean. If you go through life with your head in the sand....all people will see is an ar5e!!
When using vacuum or compressed air, do not point it directly at the cooling fans, they can break down because of excessive speeding. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6189 ![]() ![]() ![]() |
Airline to blow it out.
The machines we have at work (fruit machines, quiz machines, digital jukeboxes) all use PC towers, and the amount of crap that they suck in from a pub/club environment is unreal. used to be worse when people could smoke in them too. Just blow it out and as said, use a soft brush for the more stubborn bits. |
So a pressure washer and de-greaser is a no-no then?
Actually, back in the 80s when I was a service engineer for Tektronix, we used to wash the circuit boards down first then put them in a very slightly warm drying oven for 24hrs..
![]() I wouldn't recommend that now though... Cheers Simon |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20889 ![]() ![]() |
I don't have an air compressor but I can get some aerosol cans instead though..
![]() Mal - Funny you mention that I do have some of that too but small wipes a whole box full. Ideal before applying anything like adhesive stickers and so on too. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
