Home > Maintenance & Modifications > Ashcroft air locker
BigMike
Ashcroft air locker
Post #65895 1st Apr 2011 3:48pm
TJ101
Yep, about 70 odd sold already, so i have been told,, nice bit of kit Smile California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #65913 1st Apr 2011 6:36pm
BigMike
It is. I got mine in Dec. Has been faultless. Just seems to have taken them ages to "officially" release it for sale.
Post #65921 1st Apr 2011 7:40pm
Anderzander
Yes - I fancy one.
What compressor are you using Mike?
Post #65926 1st Apr 2011 8:36pm
BigMike
Standard ARB one, mounted in the drivers seat box. switches are to the right of the steering wheel in the small aperture. I made a plate to fit them into then bent it back at around 70 degrees. By all means take a look in May when we go to swaledale Thumbs Up
Post #65933 1st Apr 2011 9:05pm
BigMike
In fact this reminds me. I should really sell the "old" diff, it's only done 6,000 miles after all.
Post #65935 1st Apr 2011 9:16pm
Anderzander
Love to look Mike Thumbs Up
The switch location sounds a great idea. I was thinking of going the T Max route and in with the battery. I'm not decided on the whole thing yet though.
I've another Landy I want to put some money into before I buy the locker.
Post #65939 1st Apr 2011 9:58pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Keep the old diff then if you sell the 90 easy to swap back. MMmm would fit the front on a 110 Whistle Original Member Pie n Pea Club.
110 HCPU Tipper
Post #65950 2nd Apr 2011 6:54am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
What does one actually need to buy and do to upgrade both diffs from standard to ashcroft air locked.
The simplest way, but best result (pegged or non pegged?, etc...)
Post #243455 14th Jun 2013 8:07am
jst
you need the actual locker which you can then build into the diff yourself or get it built in for you. its not an unbolt/rebolt job though
you will need an actuation system - so an air compressor (ARB or similar) or a halfords comp and a drinks bottle will work
some 6mm pipe and fittings and and air solenoid to actuate the feed to the locker.
(i believe pipe, solenoid and fittings come with Daves locker)
if your sticking with 3.54s then i wouldn't bother with having it pegged. if your going for 4.11 which means you have bigger then stock tyres and prob >33" OD then it may be worth considering. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #243488 14th Jun 2013 10:22am
Even if you're sticking with standard ratios you may want to consider fitting an Ashcroft HD ring & pinion set in the diff. The extra cost is not great, and if going to that much effort anyway, why not get the best you can.
Post #243492 14th Jun 2013 10:38am
zone30
Thx guys, now I have a better idea howto calculate the cost.
Post #243894 15th Jun 2013 8:04pm
Drover
Australia
You should, if finances permit, seriously consider the new Ashcroft HDP38 replacement centre complete with locker.
Avoid all the issues that the stock centre will bring you in the future.
Post #244002 16th Jun 2013 10:17am
zone30
Thx, will look into that too.
Post #244098 16th Jun 2013 4:25pm
