Home > Td5 > TD5 Cooling Hose Question
johnnyd
Quick Question......Why are there only 3 hoses in a replacement hose kit for a TD5? If I open the bonnet I see more than 3 hoses ?
http://www.paddockspares.com/pm992-silicon...r-td5.html
http://www.ebay.co.uk/itm/AlliSport-Land-R...3a69c64c06
JD 2008 TDCi 2.4 XS CSW
Post #243226 13th Jun 2013 1:44pm
Martin
Site Admin
They are the air hoses, not coolant!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #243228 13th Jun 2013 1:45pm
johnnyd
Isn't a coolant hose more important than an air hose though ? Why just replace the air ? 2008 TDCi 2.4 XS CSW
Post #243230 13th Jun 2013 1:46pm
Martin
Site Admin
Some people just like shiny blue things? Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #243232 13th Jun 2013 1:48pm
They do completely different jobs. Manufacturers typically use a similar material for both as it's cheap and generally does the job. There are benefits to upgrading to materials that are more specifically suited though, albeit at a cost. Darren
Post #243237 13th Jun 2013 2:10pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
The 3 that you are talking about are almost certainly for the intercooler, they help to stop expansion when under high boost pressure from the turbo, I did mine a few weeks ago, not sure if it helps much, mine's only a mild stage 1 with larger intercooler etc, but yes, they are shiney blue ones!!
I don't suppose that the coolant hoses are under so much pressure when boost is required.
It's a bit like adding braided hoses to the brakes, it just stops expansion, allowing the pressure to go directly where it's meant to go and not outwards (if that makes sense)
Post #243376 13th Jun 2013 10:22pm
