![]() | Home > In Car Electronics > How do you extract an Alpine head unit? |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 463 ![]() ![]() ![]() |
Yes there was a label on the top of the radio with the wiring connections, it didn't match the diagram I downloaded but I figured the label actually on the set should be right and sure enough it was. The wire concerned was blue/white, which is a colour I have heard mentioned on other threads but didn't want to use without confirmation.
Alls well now and the LR is 'Woofing'. Thanks to all contributors. John. 2.2 90 XS 88" Series One Old Norton ![]() Modern Honda and Harley |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
|Is it possible to get the alpine unit out without the proper keys/tool if so where are the locking tabs in relation to the unit?
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808 ![]() ![]() ![]() |
Small screwdriver each side to spring the lugs located at the top each side
![]() 2008 SVX 90 2000 XS TD5 90 |
Thanks Suli
