Home > Puma (Tdci) > Another (!) Snorkel question....
Page 3 of 4 <1234>
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Thumbs Up
Looks great Glyn.... what size are your M/T's, matey? Mark
2011 110 XS DC
Stornoway Grey
Post #24219 13th Feb 2010 5:31pm
Glynparry25
They are 285/75/16....Which I think is the prefered weapon of choice on the Defenders Smile
Glyn
Post #24221 13th Feb 2010 5:34pm
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
MuddyMarky wrote:
All joking aside, anyone noticed any significant drop in performance/decrease in MPG etc since fitting their snorkel?
Hello,
I don't check neither how many litres i put in my tank nor how many km i've done but my Puma was the same before and after I've fitted the RAI.
Hope it will help you
Post #24263 14th Feb 2010 12:13am
110SEB
We can't tell the difference either. The OE snorkel is pretty aerodynamic, but the 110 is so UNaerodynamic that it makes little/no difference!
Post #24281 14th Feb 2010 9:26am
K9F
Drilling Requirements?
With the different types of Snorkel available the 'Safari Type' require you to carry out some drilling according to the Devon 4X4 description: Quote:
"An accurately marked template is also provided to ensure that the installation of the snorkel body to panel work is as precise as possible and eliminates any guess work where holes need to be drilled."
Whilst the description for the Safari is comprehensive and clear the Mantec one isn't.....
My question is thus...Does the Mantec snorkel also require you to drill the bodywork?
Thanks. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #24283 14th Feb 2010 10:34am
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Yes, but its a peice of Censored to fit.
Took me and Discocuzzy about 4 brews and 20 mins.
AndrewS has posted a picture guide in the gallery. Just do a search for it.
Post #24285 14th Feb 2010 10:44am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I Went off AndrewS Description in is gallery...Very easy 30 mins Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #24287 14th Feb 2010 10:47am
K9F
Surface Finish!
Higgers, Fekete,
Thanks guys, did you restore the surface finish on drilled panelwork? One would surmise a suitable paint or primer would suffice? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #24296 14th Feb 2010 11:47am
MuddyMarky
It looks like the TD5 version is much smaller where it attaches to the wing, almost like it doesnt require drilling, except the A-pillar. Mark
2011 110 XS DC
Stornoway Grey
Post #24311 14th Feb 2010 2:14pm
fekete
Re: Surface Finish!
K9F wrote:
Higgers, Fekete,
K9 me old mucker Snorkel mack 5 you've got to be doing something right with her in doors Thumbs Up yes i put some spray on the bare metal....Also when drilling the pillar be careful as there are wires behind the plastic trim...if you haven't got a riv nut tool Mal use this Methad it worked for me
http://www.x-eng.co.uk/rivnut.asp NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #24312 14th Feb 2010 2:21pm
K9F
Tuckerpops!
Thanks Fekete,
Tuckerpop rivets would also do the trick! Will see what's supplied. Long story but death brings out the worse in people! Having been to four funerals in the preceding 12 months (including my mum's) have decided 'You're a long time dead and life is too short!' B0llox if there's something you really want and obtaining it doesn't cause any hardship just get it or regret it later in life.
Will step down off my maudlin' soapbox now! Apologies! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #24317 14th Feb 2010 3:10pm
fekete
No drama mate that's exactly how i feel if you want something get out there and get it...as you say your a long time dead..... Enjoy yourself now and don't have any regrets. Thumbs Up
How's the knee doing mate hope all went well NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #24340 14th Feb 2010 8:59pm
K9F
Thanks matey! Had appointment last Tuesday, poking and prodding done, pre-op swabs taken to make sure I haven't got MRSA just waiting for op date! Reckon with my clutch it may be a couple of weeks before I'll have the strength to push it after the op! Will be trying on a daily basis I reckon! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #24346 14th Feb 2010 10:08pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Mantec dead easy to fix. You'll need a rivnut tool or the x-eng solution but that's about it.
I put tape on the wings to stop my drill bit wandering but that was about it. They're aluminum and I used ally rivnuts so no real need to treat. I added a bead of silicone around the gasket when fitting to try and get a bit tighter to the body (don't know whether it did anything).
Just watch for the wires - especially on the A-post. Make sure you take the trim off the inside and move them first. Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #24355 14th Feb 2010 10:47pm
mse
Friend of mine just binned his mantec one for a safari snorkel - sick of the mpg drop said he could hear the difference Mike
Post #24543 17th Feb 2010 6:18pm
Page 3 of 4 <1234>
