![]() | Home > Off Topic > Air Valve help |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
I am in the marine sector and each vessel has 6 compressors onboard so we do use a lot of unions valves etc. Can you give any explanation of what it actually is (for example is it an NRV - it does look like one, pressure reducing etc.) what it's for and thread size? I may possibly be able to help perhaps?
Or you could direct you query to 'someone in the know' see links below.... http://www.airlinefittings.co.uk/pneumatic...cat_3.html http://fittingsandadapters.com/ http://www.airlines-pneumatics.co.uk/produ...&prod= Treat every day as if it is your last....one day you will be right!! |
| jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134
Unnecessary quote removed
Thanks K9F, I found something very similar size wise and with the same thread, can NPT be gotten on this side of the water? It's an air fitting, it's used to fill an air bladder inside a steel mandrel which pushes out pins to hold a roll of material. http://www.jrcweb.com/HD_Air_Valve_p/a-1597.htm Tdci 110 DC |
Not sure but did a trawl for something similar without success.
Try sending JRC a message they may well ship..... Treat every day as if it is your last....one day you will be right!! |
I think I got sorted should know by Monday thanks for the help K9F |
Good news, did you contact JRC direct or find an alternative source? If you go through life with your head in the sand....all people will see is an ar5e!!
A kind of of local machine shop had one on the shelf gathering dust, so I got lucky! I'm going to order two now for some spares. Tdci 110 DC |
| All times are GMT |
