![]() | Home > Puma (Tdci) > De-cat pipe needed? |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Hamish
glad you're enjoying .. oh and so envious of your location albeit shipping might be expensive. I'm no good on doing searches but if you have a go I'm sure you'll come across other threads where exactly what you've described has been done. and to the best of my knowledge has worked fine. good luck. ![]() |
YES! ![]() Page 4 with pretty pictures..... ![]() http://www.defender2.net/forum/topic15424....p;start=45 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 4th Jun 2013 1:46pm. Edited 1 time in total |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
I have one I brought from BAS and never fitted.
![]() ![]() Too many projects on the go at once, many of them "wife-related" ![]() But shout it at them in German because life is also terrifying and confusing... |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
Hamish, you can remove the cat, drill out the contents and re-fit. Save the bucks for more beer
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
Does the noise increase at the back? i want to hear some turbo
![]() And i presume mpg will increase and it will rev slightly easier? William |
I can't say that I can hear the turbo more, but then it's been bucketing so hard here it's hard to hear anything else. ![]() I also cannot correlate increase in mileage/drivability since I also did the BAS v2 remap at the same time. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 ![]() |
Thanks for the feedback guys. Zedefender - those are great pictures from the 2012 thread... but I'm a bit confused as you've said you haven't done yours yet... - have you drilled it out but not fitted it yet?
Oh another question. When I remove and refit my prop shaft, should I be using a torque wrench to tighten back up? If so, does anyone know how tight? I'm a bit of a novice when it comes to these things - but looking forward to getting messy with my defender... cheers, Hamish
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
just do them up tight. prop shaft tool from difflock helps alot too. Cheers
Ok so I drilled out the cat material - lots of mess and dust. Quite an easy job and results are great. I also got the mid-box silencer removed and a new piece of pipe welded in. Second day driving it and has a real noticeable difference. More pull, turbo appears to spool up quicker - as everyone else commented it would. Strange thing is it doesn't sound any different - I would have thought that removal of the mid silencer would have made more of a throaty but it hasn't... wondering if the decat downpipe would make a difference here vs me just punhcing out the material of the existing pipe (with the bulge in it). Someone suggested I take off the battery leads for 24 hours to let the ECU 'reset' to a new exhaust system... ? Anyway, sound aside I'm pleaased with it. Remap next!
sounds promising then.
wasnt Zaks going to do to de-cat tests? does anyone know if they were done? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
