Home > Puma (Tdci) > Fuel breather?
Hans
France 2008 Defender 110 Puma 2.4 SW Keswick Green
Fuel breather?
I read something about problems with the fuel breather on Pumas (LR changed the design or location to prevent this?). Because mine sometimes has a very noisy engine, mostly in cold/humid weather, I wonder if water gets into the diesel through the breather.
Is there an easy way to check if the fuel breather is OK? Hans
http://www.orlaya.fr
Post #24059 11th Feb 2010 11:48am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Looky here
http://www.defender2.net/forum/topic2067.h...l+breather Original Member Pie n Pea Club.
110 HCPU Tipper
Post #24063 11th Feb 2010 12:01pm
Hans
Thanks for the link. They talk about an image that shows the breather location, but the image is not visible in the thread.
Could anyone post it?
How to interpret the VIN-number? Mine is longer than the one mentioned in the thread.
The car has been to the dealer's several times (still under warranty) because of water in the diesel. But they never really solved the problem. They once charged replacing the diesel filter because the water 'came from using bad diesel, so not covered by warranty'.
When the engine becomes noisy, I stop and clean the common rail pressure sensor and it runs smooth again. I'm pretty sure the problem is not due to the diesel I use. I've had MIL problems several times and they disappeared after cleaning the sensor. I would like to get this solved before the car goes out of warranty. Hans
Post #24065 11th Feb 2010 12:28pm
willy eckerslike
http://www.defender2.net/forum/topic1969.h...l+breather Original Member Pie n Pea Club.
110 HCPU Tipper
Post #24066 11th Feb 2010 12:33pm
Hans
Thanks!
Now following a course on 'how to use this site's search feature' Shocked Hans
Post #24067 11th Feb 2010 12:46pm
puma 90
2008 Defender 90 Puma 2.4 SW Zermatt Silver
...took out my back seats to gain some space for camping trips and relocated the breather pipe to the inside of my car. Used one of the holes after taking out the seats.
Had also a nocking noise, now it sound ok. Touching wood!!!!!!
Post #24791 21st Feb 2010 8:09pm
Hans
Despite the pictures on this forum I couldn't locate the breather pipe on my car. It should be somewhere below one of the rear wheel-arches but I just can't see it. Any hints? Hans
Post #24823 22nd Feb 2010 9:57am
Eduardo
From memory only
Should be located in one of the rear wheels arch.
If I remember well it is clipped to the rear pannel in the arch at the left side.
Cheers Eduardo
Post #24840 22nd Feb 2010 1:49pm
Hans
Eduardo wrote:
From memory only
Thanks, Eduardo, I'll check again and see if I can find it. Hans
Post #24841 22nd Feb 2010 1:56pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Eduardo wrote:
From memory only
as above. Should be in the LHS rear arch - towards the back. If it isn't there, try behind the plastic trim at the back of the arch - sometimes the dealers have relocated them there to prevent mud and crap getting into them. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #24918 23rd Feb 2010 10:44am
