Home > Puma (Tdci) > 57 plate 2.4 puma XS Central locking and starting problems
jameshutch
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
My Defender's central locking packed in but we could still open it up with the key so i just presumed it was the battery when getting into the car and trying to start the engine it cut out and all the alarms go off! I've checked all the fuses and changed the batteries in both keys but still no joy Sad I love the vehicle but the electronics are driving me crazy!!!!!!! Mad
Has anyone had any similar problems or even better know how to fix it?
Thanks
Post #240440 2nd Jun 2013 1:41pm
Sockpuppet
Does the emergency code disable the alarm. If it does then it could be a reciever for the alarm.
Post #240441 2nd Jun 2013 2:02pm
jameshutch
how do you find the emergency code?
Post #240443 2nd Jun 2013 2:05pm
Handbook most likely. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #240472 2nd Jun 2013 4:39pm
Toplink
Sounds like a knackerd fob unit.I have a 57 plate and have had to replace 2 fob units so far.
Aparently all the elecronics on LandRovers are customer led inovations Big Cry Well thats what one of Guy Salmons sales guys told me,at the time I was telling him that electronic hand brakes are crap. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #240482 2nd Jun 2013 5:57pm
ickle
Emergency Key Access code should be in the handbook, otherwise you'll have to get someone with a reader to get if off the ecu.
Keith
Post #240486 2nd Jun 2013 6:15pm
rossy
have you followed the fob battery changing instructions in the manual to the letter ?
IE Within the vehicle and within 5 minutes :
1) turn the key to position 2 and then remove it
2) Prise off the fob cover from the key ring end
3) remove the battery from the bottom with a small flat end screwdriver
4) press either lock or unlock button to remove any residual current
5) Insert a CR2032 battery + sign to the top/front
6) Push the cover back on the fob and from outside the vehicle press the lock button at least four times until it locks - then unlock. Job done !
I replaced my battery recently simply because its been in for 2 years now and there's quite a few posts about all sorts of shenanegans resulting from worn out fob batteries Thumbs Up
Post #240493 2nd Jun 2013 6:53pm
