![]() | Home > My Defender > Defender 90- 1995 300TDI |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3411 ![]() ![]() |
nice work!!
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 267 ![]() ![]() ![]() |
Is that a 1750 GTV Alfa sitting next to it in the paint shop?
Nice transformation of the 90 by the way ![]() ![]() |
SachaR Member Since: 28 Feb 2013 Location: Udine Posts: 40 ![]() ![]() ![]() |
Thanks, I think if I remember it was just a Alfa Giulia, |
Wow, your 90 looks amazing! You've got by far the best engine, the 300 Tdi (Not that I'm biased
![]() ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
It is a great looking 90 in the photos and in the flesh, pleasure to meet you and glad you was happy with the service
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Defpuma Member Since: 10 Feb 2013 Location: Kent Posts: 84 ![]() ![]() ![]() |
Great job. Really nice looking fender!
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
Wow, you don't muck around do you.....all that work in such a short time....great work, and a new "life" for a 90.
Cheers, Pickles. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
looks like it new not 18 well done DEFENDER 90 TDCI XS,
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
Very nice! Wish I had done my 90 in Stornoway it looks the nuts.
Thanks guys for the comments!!
![]() Cant wait for the new cubby box and seats to arrive from Killer so as to finish off the interior. |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
Top job
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Nice
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Massive improvement, very nice indeed.
Time for a update! Having finished the racing season, I finally had time to put some effort into finishing the interior. In the end this last year my defender has only seen some muddy fields and some long motorway cruises but if all goes well it should do some green laning in the next months or so if it ever stops raining!!
On the exterior I only added the LR centre caps to the alloys and added a nice Falon nameplate to the rear, I had seen a few on the forum and they finish off the rear really nice ![]() Click image to enlarge After which it was a start on the interior, first step, recover the MUD centre console with vynil which matches the rest of the interior. Added to this was a set of Carling switches which commands the lights and other things. Note that I have removed the auto system from the CSK DLR bumper and wired them into a switch as well as adding a MOMO controller that switches the DLRs off when the lights are switched on. Having added interior LEDs to all the lights, I decided the dash was in need of some renewal as 90% of the lights behind the gauges were blown, on closer inspection, the bulbs had not only blown but also fused to the plastic and so new gauges were needed. ![]() Click image to enlarge I found some funky electronic ones that looked ok and a new fuel gauge in a matching gauge is on order if it ever arrives!! ![]() Click image to enlarge My little helper hiding away!! ![]() Click image to enlarge With the new steering wheel from Chris at CSK, the interior was starting to look good! ![]() Click image to enlarge Then I decided to add some lights to the rear footwells to help when searching for thing you drop, I had a set of home interior LED spots that run on 12v and after some testing decided to fit those as they did the job very well! Well worth using home lighting as you can find them at a much lower price that the car lighting. ![]() Click image to enlarge Once the interior lighting was finished it was time to move onto the door cards. During the initial build I had covered them with Alcantara but I was not happy with the finish, between the bad job I had done covering the door cards and the actual material itself, finding a different material was high on the list. On a trip to my local car parts place, I found a roll of vynil fake leather with cube/carbon fibre effect and decided to use this. I proceeded to glue and fit this material which came out well. Being vinyl you could do as with sticker and heat up the material so as to stretch it round the corners and if you heat it up enough, it then keeps this shape. Working the vynil: ![]() Click image to enlarge Finished item: ![]() Click image to enlarge Finally, to finish off the interior I bought a set of SVX type seats from Chris at CSK which finished of the interior a treat!!! Although I am still debating on some finishing touches such as removing the alcantara of the dash and replacing it with the same vinyl as the door cards. ![]() Click image to enlarge The big descision now is the rear, do I leave the bench seats in or update to Puma type back seats or the exmoor trim type?! 1995 300TDI CSW 90 1968 Mini Innocenti |
