Home > 130 > Chewy's 130 Restoration Thread!
Page 2 of 2 <12
Stoney
1996 Defender 90 300 Tdi SW Epsom Green
Looks like a great truck can't wait to see what you do with it Thumbs Up
Post #239576 29th May 2013 9:59pm
chewy7
Australia
And here it is now..Ready for the old motor to come out Smile
Post #241243 5th Jun 2013 4:17pm
chewy7
Australia
So i've finally got an update on this Smile
I bought a 2010 110 SW Puma 2.4, which had been rolled. Its basically got all the wiring, engine, gearbox, transfer, etc that will fit directly to the 130.
My only issues i'm thinking is:
- Fuel tank?
- ABS, how do i remove it ???
- Cutting the old engine and gearbox mount brackets from the Puma and welding and positioning them onto my 130 chassis.
Do you guys have any ideas? The Puma starts and drives without any issues. It even has HID spot lights, dual batteries, LRA long range fuel tank ( can i retro-fit this into the 130?)
I'm also planning on salvaging the doors from it and repairing the bulk head too. I know they look horrible, but hopefully be able to find someone competent and up to the task.
Post #266336 13th Sep 2013 4:24pm
pjb
I think I would perhaps look at re-bodying the 110 with the 130 body rather than the transplant the other way Exclamation
Chassis mechanicals etc look good so may be an easier proposition & give you 2010 vehicle when you've finished
I'm not at expert but hopefully one will be along soon Very Happy 2020 P300 HSE
Post #266351 13th Sep 2013 5:15pm
What an excellent project. Good luck! Darren
Post #266359 13th Sep 2013 5:34pm
Romadog
Would love the winch bumper !
Post #266409 13th Sep 2013 8:01pm
Very similar to a BRB one from David Bowyer (or direct from PWS bars)
Pretty good, but so so so heavy! I've had two. changed back to a factory plain winch mount now, and handling and suspension issues are a thing of the past.
Post #266427 13th Sep 2013 8:43pm
Given OPs location it may be an original ARB bar - I think DB used to import them before he designed his own version...
They also do a "plain" bumper:
I had a Bearmach version back in the day and can speak for the weight of this style of bar!
Post #266537 14th Sep 2013 8:19am
chewy7 wrote:
Can't help but be drawn to the slanting lines of the roof at the rear and think it actually suits the vehicle. Kind of reminds me of those National Geographic car advents of many years ago:
Post #266543 14th Sep 2013 8:33am
Tiger
Surely just rebody the 110?...????
You've got all the bits be done in a weekend and have a load of left overs to sell.
You could then use the extra time to practise at cricket
Post #266547 14th Sep 2013 8:40am
chewy7
Australia
Yeah i'm not sure what path to head down. I could use parts of the 130 and make a 110 double cab. Put i would prefer the extra space on the 130 tub. Although it would be remarkably easy to fix up the body on the 110. I removed the roof today, and it was a breeze. Like a big lego set! Very Happy
Any ideas how i could disable the ABS and TC on the 110 when fitting it to the 130?
Post #266572 14th Sep 2013 10:59am
DJWillis
Assuming your going down the road of putting a Puma on that 130 who not just take over the ABS/TC as you will be extending all the loom and bringing over the ECU and friends? If not I would assume your into using some ECU firmware tweaks to kill it off electronically (talk to some of the modders, Porny @ IRB should know how) and also you will need the mods to make sure nothing is left behind that would fail your MOT.
I am about as far from an expert on this as you could get but I am sure the 110's ABS/TC from both Puma's and TD5's has been used on 130's in various situations by LR, that said I know it is not on current 130's out of the factory.
A Puma 130 could be awesome esp. as you have so much of the Puma to work with. That said, redoing the Puma with the 130 bits and cashing out is the easier option surely? Smile.
Edit: For the record, I would go 130 and just accept it is a money pit of joy Wink.  John - Random Defender Owner
Daily Driver - '87 300TDi Rebuild in need of yet more work Very Happy
Post #266733 14th Sep 2013 8:57pm
roamingman
if you want a 130 go for it, don't let other people talk you out of it. We have a 127 camper our's has a 3.9 Isuzu engine, on the Australian forum their is a lot with this engine. Thumbs Up Live Life Ti'l You Die
Teddys are out thier
http://teddybearspicnic.webs.com
http://130sasha.co.uk/
Post #267207 16th Sep 2013 3:45pm
Page 2 of 2 <12
