Home > Puma (Tdci) > help !!
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
help !!
guys. have a problem ! coming back through Gibraltar immigration, the car was stationary, got waved on by the copper, put her into gear and then the clutch pedal just fell to the floor, there was a bit of a crunch... then couldnt get a gear, lifted pedal but any pressure just pushed it back to the floor as if the spring wasnt attached.
Then couldnt get a gear. Took a look below and a nice pool of fluid, on further inspection there appears to be a 5mm hole in the gearbox..
Can anyone help with what to do next. THe dealer i purchased from gave me a years graentee on gearbox, but i have a feeling he will says its wear and tear or a stone or something. I seriously dount anything external made the hole.
Please take a look and let me know your thoughts and how to best handle the dealer. Sad
https://picasaweb.google.com/lh/photo/pXMe...directlink
https://picasaweb.google.com/lh/photo/afgm...directlink
I have to get the car moved from the border car park in 24 hours, the dealer is located 120km away... what would you guys do?
Post #239022 27th May 2013 7:42pm
bob neville
Going to stick my neck out but I think that hole exists on the MT82 as normal.
Best guess is the clutch master (or slave, not sure which way round it is Embarassed ) cylinder has gone (it is inside the casing), leaked and the oil is coming from the drain hole ?
Good luck.
2013 Defender 90 CSW - sold
Post #239032 27th May 2013 7:59pm
The hole is supposed to be there. The lack of pedal and fluid leaking out suggests a failure of the hydraulics - either a burst pipe or possibly the slave cylinder, which I believe is inside the bellhousing. Darren
Post #239033 27th May 2013 8:00pm
adiep
oh well... thats a relief, of sorts... any idea of how much to replace the master or slave? using a dealer?
Post #239036 27th May 2013 8:08pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Last year I was quoted:
TR51 wrote:
Master Cylinder:
£223.80 + VAT is what I was quoted by a main dealer last week
[£72.10 - master cylinder].
[£8.50 - fluid and disposal]
[143.20 - Labour]
And as you'd probably want to do the slave at the same time...
Slave Cylinder:
£103.01 + VAT
[£58.26 - slave cylinder]
[£44.75 - Labour]
@ Roger Young LR (Devon)
Hope this helps + you get it sorted without fuss Thumbs Up
Post #239038 27th May 2013 8:13pm
You can start the engine "in gear" and get going... with some practice you'll be able to change gear without the clutch, by getting the (engine) revs to match the forward speed.
Try giving Tuggy (tuggys4x4) a shout, he's in La Linea, if you don't want to get to your dealers.
Although there is (or was) a Rover dealer in Gib. surely they could sort it?
Post #239073 27th May 2013 9:31pm
JSG
Agreed, it is the clutch cylinder that has gone Thumbs Up John
2011 Tdci 110 CSW XS
Post #239082 27th May 2013 9:56pm
adiep
big thanks to all, should be easy enough to get sorted now armed with this info Smile
Post #239114 28th May 2013 4:41am
adiep
if the slave has gone, should i replace the master too? or not required?
Post #239137 28th May 2013 9:22am
Might as well. there could be some contamination of the fluid back up into the master (although the oil doesn't "move" that much when you press the pedal)
But is the slave gave out, then chances are (due to age) the master might be on its last legs too.
Post #239181 28th May 2013 11:36am
adiep
its a 2008 motor with 90000km on the clock, would that be expected?
I was running it for about 30 minutes offroad in first with no clutch, using anti-stall before it went, maybe connected? would that stress it? my 4 year old son was sat on my lap steering Smile
Post #239185 28th May 2013 12:13pm
adiep
Guys, the mechanic thinks i he needs to remove the entire gearbox to change the slave on a puma, is that right? he says its a days and half work... is that correct?
Post #239959 31st May 2013 1:09pm
bob neville
It is a gearbox out job I believe.
Not sure of the length of time needed though.
Post #239961 31st May 2013 1:12pm
