Home > Maintenance & Modifications > JW8700 install help
a13x
JW8700 install help
Fitting the JW speaker headlights with marker lamp and need some guidance.
1 connector is a simple plug and play but the other (marker lamp) is different. Question is, should there be a plug to connect on to? Or shall I cut the existing connector and crimp the cables together?
Pic of existing connector
Post #238063 23rd May 2013 5:35pm
If your Speaker headlights have a 'marker' lamp there should be a single cable coming out of the back of the headlight with (from memory) a male spade terminal.
DONT cut that plug off and crimp the two wires together, that will create a dead short
Post #238067 23rd May 2013 5:50pm
a13x
That's correct, however the 2 connectors for the headlight are what's seen in the pic above, 1 3 pin (black) and the other (white and yellow connector) for the sidelight bulb.
Post #238068 23rd May 2013 5:56pm
OK, so the positive cable on the two pin plug goes to the single cable on the headlight, the other is an earth which is not required
Post #238069 23rd May 2013 5:57pm
dgardel
Italy
Re: JW8700 install help
With a multimeter che the positive (+12V) when the side/marker is ON
Connect the single cable from the JWS to this one
take a look HERE
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #238120 23rd May 2013 8:25pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
if you have the 8700 evo with side marker lights and the 70mm drl's , you can also wire the marker to do sme has DRL's ask Tim.... Putting Dreams on Drives at JLR Solihull..
Post #238351 24th May 2013 5:05pm
Porny
Site Sponsor
Or....
If you get stuck have a quick drive down the A38 an I can make a suitable harness Thumbs Up
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #238395 24th May 2013 7:20pm
a13x
May take you up on that, I will soon have a good bit of wiring to do. Carling switches to hook up and run cables for future upgrades.
Post #238400 24th May 2013 7:41pm
adafish
Porny wrote:
Or....
Ian
........thanks, might take you up on that, any biscuits ?...need Derek's doing... Whistle Putting Dreams on Drives at JLR Solihull..
Post #238421 24th May 2013 9:35pm
