![]() | Home > Maintenance & Modifications > Another lowered Defender.... |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Pictures please
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
Sorry just going a little off topic for a minute. All this talk on lowering Defenders, this is just lowering the overall height of the body and yes whilst road handling will be undoubtably better the only way you'll compromise off road ability is by fitting smaller diameter wheels and tyres. It's the clearance between the ground and the axles that will often dictate whether you get stuck or not. With traction control or the age old method of left foot braking to find traction there is very little reason that a "lowered" Defender shouldn't go the same places as a standard Defender. Lifting motors is mainly done through the need to accomodate taller tyres which then put more space under the diffs.
| IKke Member Since: 16 Aug 2008 Location: Brabant Posts: 117
Never mind this post, misread
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Not strictly true as although you are correct about the difs being the same height you will make the ramp over angle lower and place fuel tank and filter etc closer to the ground. Approach and departure angles will also be compromised. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Yes I agree, but for the people who are lowering their Defenders aren't looking at performing many extreme moves off road, they won't be wanting mud to fall off in the garage, it might compromise the floor height
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Culminator - lowered mine by 2" since new for German car parks and no-one (including some dealers) even noticed. I get the impression quite a few old Defenders sink even lower just due to their age
I find the road handling to be fine (especially compared to an old Discovery I used to borrow, and "loaners" from the dealer). I've been over some pretty rough (but mostly dry) terrain with no complaints, though nothing as extreme as a lot of guys and gals on here do Most importantly, I can drive my 110 to work every day and park it there But shout it at them in German because life is also terrifying and confusing... |
| All times are GMT |
